Hii
i am working on jetson nano b01 board where the requirement is to encrypt the rootfs on every boot user need to type passphrase to decrypt and root part should be stay as it is (decrypted) i have used luks method to encrypt the file system ,is there any particular method to do so or link that i can follow.Thank you in advance.
Hi JerryChang,
Thank you for your response.
is secure boot supported by nano,if yes then kindly share documentation or link by which i can boot my board securely.
hello parthm,
there’s developer guide, Secure Boot session for your reference,
you should access Jetson Linux | NVIDIA Developer and check the bottom for the secureboot package.
thanks
