Hello Nvidia team,
I have a question about Rootfs A/B.
Enable Root File System Redundancy during the flashing process.
After flashing, enter the system, the default is to enter slot A .
nvidia@tegra-ubuntu:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 16M 1 loop
nvme0n1 259:0 0 238.5G 0 disk
├─nvme0n1p1 259:1 0 27G 0 part /
├─nvme0n1p2 259:2 0 27G 0 part
├─nvme0n1p3 259:3 0 100M 0 part
├─nvme0n1p4 259:4 0 768K 0 part
├─nvme0n1p5 259:5 0 512M 0 part /boot/efi
├─nvme0n1p6 259:6 0 384.8M 0 part
├─nvme0n1p7 259:7 0 100M 0 part
├─nvme0n1p8 259:8 0 768K 0 part
├─nvme0n1p9 259:9 0 512M 0 part
├─nvme0n1p10 259:10 0 384.8M 0 part
├─nvme0n1p11 259:11 0 400M 0 part
└─nvme0n1p12 259:12 0 335M 0 part
nvidia@tegra-ubuntu:~$ sudo nvbootctrl -t rootfs dump-slots-info
[sudo] password for nvidia:
Current rootfs slot: A
Active rootfs slot: A
num_slots: 2
slot: 0, retry_count: 3, status: normal
slot: 1, retry_count: 3, status: normal
I know that you can switch using the following command.
sudo nvbootctrl -t rootfs set-active-boot-slot 1
I’d like to know if there’s a way to select slot B during the flashing process, and then have the system default to slot B instead of slot A after flashing.
