My operation error caused partition A to fail to start normally, and a Kernel panic would be reported every time it was started.
After three consecutive failures, Switching the bootchain
is printed, but it still boots from partition A.
By the way, besides using the nvbootctl
command, is there any other way to switch slots?
Now even if I re-flashed the A partition, it still reboots endlessly and cannot enter rootfs.
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
Switching the bootchain. Resetting the system in 2 seconds.
����Shutdown state requested 1
Rebooting system ...
[0000.060] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0000.066] I> t234-A01-1-Silicon (0x12347) Prod
[0000.070] I> Boot-mode : Coldboot
[0000.073] I> Emulation:
[0000.076] I> Entry timestamp: 0x00000000
[0000.079] I> last_boot_error: 0x0
[0000.082] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0xb, rst_level: 0x1
[0000.090] I> Task: Bootchain select WAR set (0x5000ba65)
[0000.095] I> Task: Enable SLCG (0x5000bab1)
[0000.099] I> Task: CRC check (0x5001ea19)
[0000.103] I> Task: Initialize MB2 params (0x5000cb51)
[0000.109] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init (0x5001d981)
[0000.116] I> Task: Secure debug controls (0x5000c0a9)
[0000.121] I> Task: strap war set (0x5000ba2d)
[0000.126] I> Task: Initialize SOC Therm (0x5001bd35)
[0000.130] I> Task: Program NV master stream id (0x5000c05d)
[0000.136] I> Task: Verify boot mode (0xd4820f1)
[0000.142] I> Task: Alias fuses (0x5001095d)
[0000.146] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.153] I> Task: Print SKU type (0x5000f5f1)
[0000.157] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000078
[0000.163] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.167] I> FUSE_OPT_TPC_DISABLE = 0x000000fc
[0000.171] I> FUSE_OPT_DL�E%M 1�= 0x00000003
[0000.175] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0000.180] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0000.184] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.189] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.193] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.197] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.201] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.205] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.209] I> FUSE_SKU_INFO_0 = 0xd6
[0000.213] I> FUSE_OPT_SAMPLE_TYPE_0 = 0�&�M�
[0000.217] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.221] I> SKU: Prod
[0000.223] I> Task: Boost clocks (0x500148a1)
[0000.227] I> Initializing PLLC2 for AXI_CBB.
[0000.231] I> AXI_CBB : src = 35, divisor = 0
[0000.235] I> Task: Voltage monitor (0x50014b49)
[0000.240] I> VMON: Vmon re-calibration and fine tuning done
[0000.245] I> Task: UPHY init (0x5000d065)
[0000.251] I> HSIO UPHY init done
[0000.254] E> Skipping GBE UPHY config
[0000.257] I> Task: Boot device init (0x50000be9)
[0000.262] I> Boot_device: QSPI_FLASH instance: 0
[0000.267] I> Qspi clock source : pllc_out0
[0000.271] I> QSPI Flash: Macronix 64MB
[0000.274] I> QSPI-0l initialized successfully
[0000.279] I> Task: TSC init (0x50020a4d)
[0000.283] I> Task: Load membct (0x50011fe9)
[0000.287] I> RAM_CODE 0x4000441
[0000.290] I> Loading MEMBCT
[0000.292] I> Slot: 0
[0000.294] I> Binary[1] block-0 (partition size: 0x40000)
[0000.299] I> get_binary_info: Binary name: MEM-BCT-1
[0000.304] I> Size of crypto header is 8192
[0000.308] I> BCH load address is : 0x40050000
[0000.312] I> Size of crypto header is 8192
[0000.317] I> BCH of MEM-BCT-1 read from storage
[0000.321] I> BCH address is : 0x40050000
[0000.325] I> MEM-BCT-1 header integrity check is success
[0000.330] I> Binary magic in BCH component 1 is MEM1
[0000.335] I> component binary type is 1
[0000.339] I> MEM-BCT-1 binary is read from storage
[0000.344] I> MEM-BCT-1 binary integrity check is success
[0000.349] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[0000.356] I> RAM_CODE 0x4000441
[0000.361] I> RAM_CODE 0x4000441
[0000.365] I> Task: Load Page retirement list (0x500115b1)
[0000.370] I> Task: SDRAM params override (0x50011fc5)
[0000.375] I> Task: Save mem-bct info (0x50014fa1)
[0000.380] I> Task: Carveout allocate (0x50015005)
[0000.384] I> RCM blob carveout will not be allocated
[0000.389] I> ECC region[0]: Start:0x0, End:0x0
[0000.393] I> ECC region[1]: Start:0x0, End:0x0
[0000.398] I> ECC region[2]: Start:0x0, End:0x0
[0000.402] I> ECC region[3]: Start:0x0, End:0x0
[0000.406] I> ECC region[4]: Start:0x0, End:0x0
[0000.410] I> Non-ECC region[0]: Start:0x80000000, End:0x180000000
[0000.416] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.421] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.426] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.430] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.440] I> allocated(CO:31) base:0x178000000 size:0x8000000 align: 0x8000000
[0000.447] I> allocated(CO:43) base:0x174000000 size:0x4000000 align: 0x200000
[0000.454] I> allocated(CO:20) base:0x172000000 size:0x2000000 align: 0x2000000
[0000.461] I> allocated(CO:24) base:0x170000000 size:0x2000000 align: 0x2000000
[0000.468] I> allocated(CO:28) base:0x16e000000 size:0x2000000 align: 0x2000000
[0000.475] I> allocated(CO:22) base:0x16d000000 size:0x1000000 align: 0x1000000
[0000.482] I> allocated(CO:35) base:0x16c200000 size:0xe00000 align: 0x10000
[0000.489] I> allocated(CO:02) base:0x16b800000 size:0x800000 align: 0x800000
[0000.496] I> allocated(CO:03) base:0x16b000000 size:0x800000 align: 0x800000
[0000.503] I> allocated(CO:06) base:0x16a800000 size:0x800000 align: 0x800000
[0000.510] I> allocated(CO:10) base:0x16a000000 size:0x800000 align: 0x800000
[0000.517] I> allocated(CO:56) base:0x169800000 size:0x800000 align: 0x200000
[0000.524] I> allocated(CO:07) base:0x169400000 size:0x400000 align: 0x400000
[0000.531] I> allocated(CO:33) base:0x169000000 size:0x400000 align: 0x200000
[0000.538] I> allocated(CO:23) base:0x16c000000 size:0x200000 align: 0x200000
[0000.545] I> allocated(CO:01) base:0x168f00000 size:0x100000 align: 0x100000
[0000.551] I> allocated(CO:04) base:0x168e00000 size:0x100000 align: 0x100000
[0000.558] I> allocated(CO:05) base:0x168d00000 size:0x100000 align: 0x100000
[0000.565] I> allocated(CO:08) base:0x168c00000 size:0x100000 align: 0x100000
[0000.572] I> allocated(CO:09) base:0x168b00000 sg completed
I> MB2 (version: 0.0.0.0-t234-54845784-9c429857)
I> Emulation:
I> Entry timestamp: 0x0020b79f
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x169800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50001e80)
I> Task: Enable hot-plug capability (0x50026c6c)
I> Task: PSC mailbox init (0x50016a7c)
I> Task: Crypto init (0x500065a8)
I> Task: Enable GP-SE clock (0x50001fe4)
I> Task: DICE Identity init (0x50019e50)
I> DICE is not enabled.
I> Task: OEM SC7 context save init (0x50019550)
I> Task: I2C register (0x50001e44)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)
I> Task: Program CBB PCIE AMAP regions (0x50019b64)
I> Task: Boot device init (0x50001d74)
I> Task: Partition Manager Init (0x50001d70)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001ce48)
I> Task: Load AUXP FWs (0x5002680c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x168c00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x168900000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x172000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00
clk_check_max_rates: pex0_c3_core rate 500000000 > max 250000000
clk_check_max_rates: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rates: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized fuse_late
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
��alting RCE
I> RCE unhalt success��[ 2.674339] Camera-FW on t234-rce-safe started
TCU early console enabled.
��ful
I> DCE unhalt successful
I> APE unhalt s��
��kipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50017f04)
I> Task: Load TOS (0x50018608)
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partitiMB2 finished
��NOTICE: BL31: v2.6(release):07eea4970
NOTICE: BL31: Built : 07:55:15, Mar 19 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun Mar 19 15:02:44 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!
I/TC: Primary CPU switching to normal world boot
ESC to enter Setup.
Hi zjy523213189zjy,
Are you using the devkit or custom board for Orin Nano?
Are you trying to verify the fail-safe mechanisom to check if it could switch to another slot if the current slot is unbootable?
Or you are trying to fix the boot failed issue?
How did you perform this?
Custom board
Yes.
By dd
command. I copied from SlotB volume to SlotA. And then correction the partition_uuid in extlinux.conf
By the way, what is the difference between bootloader/system.img
and tools/kernel_flash/images/external/system.img
? Which one was used for final flash? Is system.img consistent with the rootfs partition that is ultimately mounted when running on the device?
If I want to make a differential patch through the rdiff
tool, can I use system.img to make a signature file and then compare it with /dev/nvme0n1p1 on the device?
In addition to nvbootctrl, is there any other way to set the boot slot?
It is the original system image created from <Linux_for_Tegra>/rootfs
It is the system image generated during inird flash and it would be used for external device.
system image and the signature are both generated and performed during flash, you can refer to the script for it.
Currently, you can only use nvbootctrl to switch boot slot.
Please share the full serial console log for further check.
I can’t reproduce the initial situation now, but I randomly modified the A partition, making it unbootable. I hope the redundant system can function in this case. But after printing the last line, it got stuck. Now, I can’t enter the system no matter what I do.
Full serial console log:
ESC to enter Setup.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x25f4fae98 SMBIOS=0xffff0000 SMBIOS 3.0=0x2412f0000 MEMATTR=0x24087b018 ESRT=0x240e9d418 RNG=0x264536c18 MEMRESERVE=0x2408a4f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000240e9d418 to 0x0000000240e9d450.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000254400000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000026fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000023bffffff]
[ 0.000000] node 0: [mem 0x000000023c000000-0x000000023e1bffff]
[ 0.000000] node 0: [mem 0x000000023e1c0000-0x000000024078ffff]
[ 0.000000] node 0: [mem 0x0000000240790000-0x000000024085ffff]
[ 0.000000] node 0: [mem 0x0000000240860000-0x000000024087ffff]
[ 0.000000] node 0: [mem 0x0000000240880000-0x000000024089ffff]
[ 0.000000] node 0: [mem 0x00000002408a0000-0x0000000240d27fff]
[ 0.000000] node 0: [mem 0x0000000240d28000-0x0000000240e88fff]
[ 0.000000] node 0: [mem 0x0000000240e89000-0x00000002412dffff]
[ 0.000000] node 0: [mem 0x00000002412e0000-0x00000002412fffff]
[ 0.000000] node 0: [mem 0x0000000241300000-0x000000024160ffff]
[ 0.000000] node 0: [mem 0x0000000241610000-0x000000024165ffff]
[ 0.000000] node 0: [mem 0x0000000241660000-0x000000024181ffff]
[ 0.000000] node 0: [mem 0x0000000241820000-0x00000002419fffff]
[ 0.000000] node 0: [mem 0x0000000241a00000-0x0000000241a8ffff]
[ 0.000000] node 0: [mem 0x0000000241a90000-0x0000000241c6ffff]
[ 0.000000] node 0: [mem 0x0000000241c70000-0x0000000241ccffff]
[ 0.000000] node 0: [mem 0x0000000241cd0000-0x0000000241dbffff]
[ 0.000000] node 0: [mem 0x0000000241dc0000-0x0000000241deffff]
[ 0.000000] node 0: [mem 0x0000000241df0000-0x0000000241dfffff]
[ 0.000000] node 0: [mem 0x0000000241e00000-0x0000000241eaffff]
[ 0.000000] node 0: [mem 0x0000000241eb0000-0x0000000241f4ffff]
[ 0.000000] node 0: [mem 0x0000000241f50000-0x000000024204ffff]
[ 0.000000] node 0: [mem 0x0000000242050000-0x00000002420effff]
[ 0.000000] node 0: [mem 0x00000002420f0000-0x00000002421effff]
[ 0.000000] node 0: [mem 0x00000002421f0000-0x000000024228ffff]
[ 0.000000] node 0: [mem 0x0000000242290000-0x0000000242b5ffff]
[ 0.000000] node 0: [mem 0x0000000242b60000-0x0000000242d3ffff]
[ 0.000000] node 0: [mem 0x0000000242d40000-0x00000002644effff]
[ 0.000000] node 0: [mem 0x00000002644f0000-0x000000026453ffff]
[ 0.000000] node 0: [mem 0x0000000264540000-0x0000000267ffffff]
[ 0.000000] node 0: [mem 0x0000000268200000-0x000000026860ffff]
[ 0.000000] node 0: [mem 0x000000026e000000-0x000000026fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000026fffffff]
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1976336
[ 0.000000] Kernel command line: root=PARTUUID=b52be393-6407-4d4f-955f-b9b4b63731bf rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 7237580K/8032320K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 532596K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000667] Console: colour dummy device 80x25
[ 0.000711] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000718] pid_max: default: 32768 minimum: 301
[ 0.000776] LSM: Security Framework initializing
[ 0.000799] Yama: becoming mindful.
[ 0.000819] SELinux: Initializing.
[ 0.000885] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000901] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001911] rcu: Hierarchical SRCU implementation.
[ 0.001996] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002380] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-p3768-0000-a0.dts
[ 0.002386] DTB Build time: Mar 19 2023 08:08:40
[ 0.003627] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0
[ 0.003793] Remapping and enabling EFI services.
[ 0.005007] smp: Bringing up secondary CPUs ...
[ 0.033703] Detected PIPT I-cache on CPU1
[ 0.033740] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033767] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062402] Detected PIPT I-cache on CPU2
[ 0.062412] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062425] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091028] Detected PIPT I-cache on CPU3
[ 0.091037] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091051] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122312] Detected PIPT I-cache on CPU4
[ 0.122337] GICv3: CPU4: found redistributor 20200 region 0:0x000000000f580000
[ 0.122367] CPU4: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.151677] Detected PIPT I-cache on CPU5
[ 0.151689] GICv3: CPU5: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.151707] CPU5: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.151771] smp: Brought up 1 node, 6 CPUs
[ 0.151784] SMP: Total of 6 processors activated.
[ 0.151789] CPU features: detected: Privileged Access Never
[ 0.151790] CPU features: detected: LSE atomic instructions
[ 0.151792] CPU features: detected: User Access Override
[ 0.151794] CPU features: detected: 32-bit EL0 Support
[ 0.151797] CPU features: detected: Common not Private translations
[ 0.151799] CPU features: detected: RAS Extension Support
[ 0.151800] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.151803] CPU features: detected: CRC32 instructions
[ 0.151805] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.189855] CPU: All CPU(s) started at EL2
[ 0.191677] devtmpfs: initialized
[ 0.208335] Registered cp15_barrier emulation handler
[ 0.208343] Registered setend emulation handler
[ 0.208349] KASLR enabled
[ 0.208490] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.208502] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.210444] pinctrl core: initialized pinctrl subsystem
[ 0.210997] SMBIOS 3.0.0 present.
[ 0.211006] DMI: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.211297] NET: Registered protocol family 16
[ 0.212201] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.212267] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.212325] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.212354] audit: initializing netlink subsys (disabled)
[ 0.212442] audit: type=2000 audit(0.212:1): state=initialized audit_enabled=0 res=1
[ 0.212627] thermal_sys: Registered thermal governor 'step_wise'
[ 0.212630] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.212633] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.213488] cpuidle: using governor menu
[ 0.213611] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.213683] ASID allocator initialised with 32768 entries
[ 0.213784] Serial: AMBA PL011 UART driver
[ 0.215733] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.215760] Tegra reboot handler registered.
[ 0.236913] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000
[ 0.236924] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000
[ 0.236933] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000
[ 0.236941] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000
[ 0.236949] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000
[ 0.236955] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000
[ 0.236962] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000
[ 0.236968] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000
[ 0.236974] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000
[ 0.236980] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000
[ 0.236986] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000
[ 0.236992] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000
[ 0.236998] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000
[ 0.237004] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000
[ 0.237010] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000
[ 0.237016] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000
[ 0.237023] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000
[ 0.237033] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.237051] mc-err: mcerr ops are set to t23x
[ 0.237812] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.376139] printk: console [ttyAMA0] enabled
[ 1.384934] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.391641] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.398340] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.405038] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.413752] ACPI: Interpreter disabled.
[ 1.418031] ddr-vddq: supplied by vdd-5v
[ 1.422172] ddr-vdd2: supplied by vdd-5v
[ 1.426222] vdd-AO-1v2: supplied by vdd-5v
[ 1.430452] vdd-3v3: supplied by vdd-5v
[ 1.434489] vdd-rtc: supplied by vdd-AO-1v2
[ 1.438802] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.443634] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.448619] vdd-1v8: supplied by vdd-3v3-sys
[ 1.453009] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.457570] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.462317] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.466874] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.471450] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.476258] iommu: Default domain type: Translated
[ 1.481171] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.487465] SCSI subsystem initialized
[ 1.491292] usbcore: registered new interface driver usbfs
[ 1.496789] usbcore: registered new interface driver hub
[ 1.502110] usbcore: registered new device driver usb
[ 1.507374] mc: Linux media interface: v0.10
[ 1.511652] videodev: Linux video capture interface: v2.00
[ 1.517310] pps_core: LinuxPPS API ver. 1 registered
[ 1.522278] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.531418] PTP clock support registered
[ 1.535582] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.542738] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.550431] Registered efivars operations
[ 1.554584] FPGA manager framework
[ 1.558025] Advanced Linux Sound Architecture Driver Initialized.
[ 1.564391] Bluetooth: Core ver 2.22
[ 1.567974] NET: Registered protocol family 31
[ 1.572417] Bluetooth: HCI device and connection manager initialized
[ 1.578775] Bluetooth: HCI socket layer initialized
[ 1.583652] Bluetooth: L2CAP socket layer initialized
[ 1.588708] Bluetooth: SCO socket layer initialized
[ 1.594126] camchar: rtcpu character device driver loaded
[ 1.599758] clocksource: Switched to clocksource arch_sys_counter
[ 1.800138] VFS: Disk quotas dquot_6.6.0
[ 1.804101] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.811148] pnp: PnP ACPI: disabled
[ 1.816905] la/ptsa driver initialized.
[ 1.820805] NET: Registered protocol family 2
[ 1.825296] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.834348] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.842898] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.850897] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.858813] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.865405] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.872213] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.879516] NET: Registered protocol family 1
[ 1.884087] RPC: Registered named UNIX socket transport module.
[ 1.890017] RPC: Registered udp transport module.
[ 1.894720] RPC: Registered tcp transport module.
[ 1.899420] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.905864] PCI: CLS 0 bytes, default 64
[ 1.909889] Trying to unpack rootfs image as initramfs...
[ 2.069425] Freeing initrd memory: 9120K
[ 2.075529] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.083457] kvm [1]: IPA Size Limit: 48 bits
[ 2.087787] kvm [1]: GICv3: no GICV resource entry
[ 2.092584] kvm [1]: disabling GICv2 emulation
[ 2.097044] kvm [1]: GIC system register CPU interface enabled
[ 2.102940] kvm [1]: vgic interrupt IRQ9
[ 2.106973] kvm [1]: VHE mode initialized successfully
[ 2.112818] Initialise system trusted keyrings
[ 2.117344] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.126345] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.132514] NFS: Registering the id_resolver key type
[ 2.137581] Key type id_resolver registered
[ 2.141765] Key type id_legacy registered
[ 2.145813] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.152520] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.159924] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.179299] NET: Registered protocol family 38
[ 2.183744] Key type asymmetric registered
[ 2.187838] Asymmetric key parser 'x509' registered
[ 2.192732] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.200187] io scheduler mq-deadline registered
[ 2.204717] io scheduler kyber registered
[ 2.213055] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.218653] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.224243] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.232528] tegra_dc_assign_hw_data: no matching compatible node
[ 2.238536] tegradccommon module_init failed
[ 2.242804] tegradc module_init failed
[ 2.246833] EINJ: ACPI disabled.
[ 2.251798] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.258675] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.263987] tegra-pmc: ### PMC reset level: L0
[ 2.268428] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.274803] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.721949] random: fast init done
[ 3.849427] printk: console [ttyTCU0] enabled
[ 3.854525] arm-smmu 12000000.iommu: probing hardware configuration...
[ 3.861230] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.866059] arm-smmu 12000000.iommu: stage 1 translation
[ 3.871598] arm-smmu 12000000.iommu: stage 2 translation
[ 3.877133] arm-smmu 12000000.iommu: nested translation
[ 3.882580] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.889984] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.899152] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 3.905853] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 3.912546] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 3.920090] arm-smmu 10000000.iommu: probing hardware configuration...
[ 3.926783] arm-smmu 10000000.iommu: SMMUv2 with:
[ 3.931611] arm-smmu 10000000.iommu: stage 1 translation
[ 3.937152] arm-smmu 10000000.iommu: stage 2 translation
[ 3.942684] arm-smmu 10000000.iommu: nested translation
[ 3.948136] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 3.955547] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 3.964696] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 3.971389] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 3.978080] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 3.985256] arm-smmu 8000000.iommu: probing hardware configuration...
[ 3.991865] arm-smmu 8000000.iommu: SMMUv2 with:
[ 3.996604] arm-smmu 8000000.iommu: stage 1 translation
[ 4.002057] arm-smmu 8000000.iommu: stage 2 translation
[ 4.007504] arm-smmu 8000000.iommu: nested translation
[ 4.012859] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.020178] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.029188] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.035788] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.042392] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.049716] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.059505] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.065483] tegra_profiler: auth: init
[ 4.069638] nvsciipc: loaded module
[ 4.074984] tun: Universal TUN/TAP device driver, 1.6
[ 4.080706] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.088126] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.093609] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.098702] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.104790] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.110323] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.116223] PPP generic driver version 2.4.2
[ 4.120664] PPP BSD Compression module registered
[ 4.125489] PPP Deflate Compression module registered
[ 4.130695] PPP MPPE Compression module registered
[ 4.135636] usbcore: registered new interface driver r8152
[ 4.141279] usbcore: registered new interface driver asix
[ 4.146820] usbcore: registered new interface driver ax88179_178a
[ 4.153085] usbcore: registered new interface driver cdc_ether
[ 4.159085] usbcore: registered new interface driver net1080
[ 4.164905] usbcore: registered new interface driver cdc_subset
[ 4.170980] usbcore: registered new interface driver zaurus
[ 4.176718] usbcore: registered new interface driver cdc_ncm
[ 4.182532] usbcore: registered new interface driver aqc111
[ 4.188385] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.194740] ohci-pci: OHCI PCI platform driver
[ 4.199315] ohci-platform: OHCI generic platform driver
[ 4.205035] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.211406] usbcore: registered new interface driver uas
[ 4.216887] usbcore: registered new interface driver usb-storage
[ 4.223216] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.229299] mousedev: PS/2 mouse device common for all mice
[ 4.235042] usbcore: registered new interface driver xpad
[ 4.242505] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.247970] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:24 UTC (24)
[ 4.256193] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.262599] i2c /dev entries driver
[ 4.266327] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.272119] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.277822] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.283503] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.289182] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.294860] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.300531] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.306209] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.315724] device-mapper: uevent: version 1.0.3
[ 4.320571] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.330312] sdhci: Secure Digital Host Controller Interface driver
[ 4.336663] sdhci: Copyright(c) Pierre Ossman
[ 4.341135] Synopsys Designware Multimedia Card Interface Driver
[ 4.347384] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.353608] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 4.353760] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.367088] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 4.375448] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.381109] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.391596] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.397547] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��Failed to create /rm/vdd_cpu
debugfs initialized
��[ 5.490136] hid: raw HID events driver (C) Jiri Kosina
[ 5.496045] usbcore: registered new interface driver usbhid
[ 5.501783] usbhid: USB HID core driver
[ 5.506247] tegra-dce d800000.dce: Adding to iommu group 4
[ 5.513466] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.522404] tegra234-aon c000000.aon: Adding to iommu group 5
[ 5.528845] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.536588] c000000.aon:hsp: probed
[ 5.538021] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.548363] tegra234-aon c000000.aon: init done
[ 5.548816] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 5.553171] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.559271] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 5.567895] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 5.574307] tegra23x-psc e860000.psc: init done
[ 5.574547] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 5.582717] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.588075] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.594111] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 5.618802] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 5.627458] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.634184] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.643373] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.654810] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.666208] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.677915] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 5.690475] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 5.703290] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 5.715388] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[ 5.722187] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.730749] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=97e50cbff52bc4b542b2989187109c001c01cf77
[ 5.744275] t19x_cache tegra-cache: probed
[ 5.748696] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.759601] optee: probing for conduit method.
[ 5.764197] optee: revision 3.19 (3f29c61f)
[ 5.764518] optee: dynamic shared memory is enabled
[ 5.773950] optee: initialized driver
[ 5.789451] nvpmodel: initialized successfully
[ 5.794126] tegra_hv: get_hvd: not initialized yet
[ 5.799058] user_ivc_mempool: hypervisor not present
[ 5.804780] usbcore: registered new interface driver snd-usb-audio
[ 5.811973] u32 classifier
[ 5.814753] input device check on
[ 5.818520] Actions configured
[ 5.822190] Initializing XFRM netlink socket
[ 5.827072] NET: Registered protocol family 10
[ 5.833147] Segment Routing with IPv6
[ 5.836965] NET: Registered protocol family 17
[ 5.841552] NET: Registered protocol family 15
[ 5.846173] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.859899] Bluetooth: RFCOMM socket layer initialized
[ 5.865187] Bluetooth: RFCOMM ver 1.11
[ 5.869041] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.875119] Bluetooth: HIDP socket layer initialized
[ 5.880967] 9pnet: Installing 9P2000 support
[ 5.885416] Key type dns_resolver registered
[ 5.890209] registered taskstats version 1
[ 5.894433] Loading compiled-in X.509 certificates
[ 5.910428] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 5.921154] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 5.934345] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.941613] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 5.954241] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 5.961262] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 5.973428] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 5.980323] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 5.992938] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 6.025945] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.036162] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.065516] host1x 13e40000.host1x: initialized
[ 6.070592] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.078624] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.090876] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.098851] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.111124] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.119121] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.131393] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.139375] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.151656] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.159678] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.171977] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.179967] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.192248] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.200208] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.212502] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.220492] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.232779] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.240760] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.253054] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.261041] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.273304] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.281328] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.293616] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.301596] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.313864] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.321844] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.334089] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.342074] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.354347] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.362321] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.374589] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.382565] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.394892] falcon 15340000.vic: Adding to iommu group 30
[ 6.405712] falcon 15340000.vic: initialized
[ 6.410459] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.419240] falcon 15380000.nvjpg: initialized
[ 6.423957] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.432914] falcon 15540000.nvjpg1: initialized
[ 6.437736] falcon 15a50000.ofa: Adding to iommu group 33
[ 6.446562] falcon 15a50000.ofa: initialized
[ 6.451120] nvdec 15480000.nvdec: Adding to iommu group 34
[ 6.462532] nvdec 15480000.nvdec: initialized
[ 6.467168] tsec 15500000.tsec: Adding to iommu group 35
[ 6.476837] tsec 15500000.tsec: initialized
[ 6.484239] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.501940] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.517785] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.524555] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.532368] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.539785] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.546768] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.553310] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.559771] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.568115] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 6.576281] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.585658] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.592112] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.601334] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.610716] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 6.618851] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 6.626895] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.636608] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.643396] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.652987] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.659787] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.669720] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.676623] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 6.683745] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 6.691236] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.697871] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.704581] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.711242] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 6.721029] serial-tegra 3130000.serial: Adding to iommu group 2
[ 6.727546] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 6.737262] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.743811] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 6.769799] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 6.779557] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.785160] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.793814] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 6.803434] tegra-xusb 3610000.xhci: irq 219, io mem 0x03610000
[ 6.809899] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.818399] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.825828] usb usb1: Product: xHCI Host Controller
[ 6.830835] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.837099] usb usb1: SerialNumber: 3610000.xhci
[ 6.842638] hub 1-0:1.0: USB hub found
[ 6.846528] hub 1-0:1.0: 4 ports detected
[ 6.850918] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.856477] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.864266] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.871800] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.880298] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.887723] usb usb2: Product: xHCI Host Controller
[ 6.892726] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.898984] usb usb2: SerialNumber: 3610000.xhci
[ 6.904315] hub 2-0:1.0: USB hub found
[ 6.908194] hub 2-0:1.0: 4 ports detected
[ 6.931589] i2c i2c-2: Added multiplexed i2c bus 9
[ 6.936881] i2c i2c-2: Added multiplexed i2c bus 10
[ 6.941900] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 6.948874] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 6.970211] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1559000 KHz, changing to: 1510400 KHz
[ 6.983904] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1564000 KHz, changing to: 1510400 KHz
[ 6.995832] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 7.002846] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.004814] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.010774] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.021409] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.023730] irq: IRQ283: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.030097] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.037780] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[ 7.046398] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.119766] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[ 7.289230] usb 1-3: New USB device found, idVendor=2c7c, idProduct=0435, bcdDevice= 3.18
[ 7.297647] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.304989] usb 1-3: Product: LTE Module
[ 7.309013] usb 1-3: Manufacturer: Quectel, Incorporated
[ 7.314474] usb 1-3: SerialNumber: 21e48163
[ 8.140214] tegra194-pcie 14100000.pcie: Phy link never came up
[ 8.146395] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.153197] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.158830] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.168665] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.179476] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.187413] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.193763] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.209901] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.215293] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.224396] pcieport 0001:00:00.0: Adding to iommu group 8
[ 8.230364] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 8.237017] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 8.243043] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 8.249171] pci 0001:00:00.0: Removing from iommu group 8
[ 8.254729] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 8.263194] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.271172] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.278350] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.287040] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.295720] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.411973] tegra194-pcie 14160000.pcie: Link up
[ 8.428324] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.435141] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.440777] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.450891] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.461723] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.469642] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.475962] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.486521] pci 0004:01:00.0: [1e95:9100] type 00 class 0x010802
[ 8.492878] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.505913] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.513343] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.521301] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.526671] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.534032] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.542768] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.551713] pcieport 0004:00:00.0: Adding to iommu group 9
[ 8.557613] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 8.564049] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 8.570124] nvme 0004:01:00.0: Adding to iommu group 9
[ 8.575892] nvme nvme0: pci function 0004:01:00.0
[ 8.580838] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.586785] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 8.594632] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 8.601821] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 8.606913] nvme nvme0: allocated 64 MiB host memory buffer.
[ 8.610506] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 8.610509] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 8.648504] nvme nvme0: 6/0/0 default/read/poll queues
[ 8.661106] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 9.724098] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 9.730277] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 9.737090] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 9.742724] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 9.752838] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.763664] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 9.771585] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.777898] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 9.793031] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 9.798419] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.807411] pcieport 0007:00:00.0: Adding to iommu group 10
[ 9.813395] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 9.819806] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 9.825938] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 9.832037] pci 0007:00:00.0: Removing from iommu group 10
[ 9.837681] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 9.845275] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.852105] vdd-3v3-sd: supplied by vdd-3v3
[ 9.858434] tegra194-isp5 14800000.isp: initialized
[ 9.866808] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.873282] (NULL device *): fops function table already registered
[ 9.881387] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.888561] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.888776] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.900347] irq: IRQ291: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.908842] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[ 10.016732] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 10.023904] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 10.032590] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 10.041270] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 10.155922] tegra194-pcie 140a0000.pcie: Link up
[ 10.163637] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 10.170454] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 10.176094] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 10.186209] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.197033] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 10.204947] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.211268] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 10.221941] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 10.228261] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 10.234179] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 10.241279] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 10.249292] pci 0008:01:00.0: supports D1 D2
[ 10.253686] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 10.265664] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 10.273093] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 10.279800] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 10.287770] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 10.295733] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 10.302387] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 10.307757] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 10.314377] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 10.321727] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 10.330465] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 10.339423] pcieport 0008:00:00.0: Adding to iommu group 11
[ 10.345415] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 10.351830] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 10.358980] irq: IRQ293: trimming hierarchy from :pmc@c360000
[ 10.364970] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.372690] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 10.380448] tegra-se-nvhost 15810000.se: Adding to iommu group 39
[ 10.387057] tegra-se-nvhost 15810000.se: initialized
[ 10.393923] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.400359] tegra-se-nvhost 15820000.se: Adding to iommu group 40
[ 10.406936] tegra-se-nvhost 15820000.se: initialized
[ 10.415155] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.421563] tegra-se-nvhost 15840000.se: Adding to iommu group 41
[ 10.428132] tegra-se-nvhost 15840000.se: initialized
[ 10.438739] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.445769] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.452120] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.458319] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.466731] hvc_sysfs: hypervisor is not present
[ 10.507013] ALSA device list:
[ 10.510079] No soundcards found.
[ 10.514478] Freeing unused kernel memory: 3968K
[ 10.519245] Run /init as init process
[ 10.539615] Root device found: PARTUUID=b52be393-6407-4d4f-955f-b9b4b63731bf
[ 10.953257] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 12.924356] random: crng init done
[ 23.856730] ERROR: PARTUUID=b52be393-6407-4d4f-955f-b9b4b63731bf mount fail...
It seems watchdog has been initialized correctly on your board.
So, it will trigger reset after stuck for more than 120 seconds.
Please also share the result of the following command on your board.
$ sudo nvbootctrl -t rootfs dump-slots-info
However, the system did not reboot after 120 seconds.
I am currently unable to access the system, so I cannot execute this command.
It seems something causes watchdog failed due to this approach.
Could you try to destroy rootfs slot A through removing /lib
as this topic?
I tested it, and in this situation, the watchdog is effective. After three failures, it successfully switched to another slot. However, we hope to be able to switch in any failure scenario, including when the watchdog fails. Is there a way to achieve this? For example, a hardware watchdog
Is it possible to change the boot slot by modifying the ESP variables?
May I know the use case to configure it from UEFI variable instead of using nvbootctrl command?
I’m afraid that if the situation described above occurs and it becomes permanently unbootable, we can mount the SSD using an external device and modify the variable values to enable it to boot from another slot.
Currently, once this situation arises, I can only restore it by re-flashing the image, which is too troublesome.
Currently, you can select the external NVMe SSD as boot device from UEFI menu for this use case.
It seems the issue is caused from mounting failure of filesystem so that the watchdog is not working.
We’ve fixed this issue in the latest JP5.1.3(R35.5.0) and also JP6.0GA(R36.3.0).
You can move to one of these 2 releases to verify.
I tested on r36.3, and the watchdog can be triggered normally. Thank you.
