Rootfs encryption on Drive OS 6.0.8.1
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I am using the Linux as the guest OS in the Drive Orin. I need to encrypt the root file system of both of the boot chains A and B, and be able to decrypt them at boot time with the use of the initramfs image provided by the SDK. I have not seen information about this in the documentation of the Drive OS 6.0.8, I have only seen that you can encrypt the /home directory with the use of a systemd service.
Is there a way to implement the rootfs encryption and decryption?
Thanks in advance.
Regards.
Is like you want to encrypt/decrypt entire rootfs. I doubt if it is possible. Let me check internally and confirm.
It is not possible to encrypt entire rootfs
