i built a custom kernel and wanted to flash the image with the flash.sh
script as follows:
./flash.sh jetson-xavier-nx-devkit mmcblk0p1
The flash exits with the following error:
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
/data/Linux_for_Tegra/bootloader/ramdisk_tmp /data/Linux_for_Tegra/bootloader /data/Linux_for_Tegra
30402 blocks
_BASE_KERNEL_VERSION=4.9.201-tegra
cp: cannot stat ‘/data/Linux_for_Tegra/rootfs/etc/wpa_supplicant.conf’: No such file or directory
failed command: cp -fv /data/Linux_for_Tegra/rootfs/etc/wpa_supplicant.conf /data/Linux_for_Tegra/bootloader/ramdisk_tmp//etc/wpa_supplicant.conf
I got the sources with the source_sync.sh -k tegra-l4t-r32.5.1
command, and used corresponding l4t
and sample rootfs
releases.
The complete log is attached here:
error.log (11.2 KB)
