We are using our custom board.
Previously, we already set the rootfs on sata SSD from our system with JP4.6.1.
It is working well. console_log_jetpack_4.6.1_sda1.txt (40.5 KB)
Now, we are installing JP5.0.2 on same system.
Installation process are same with before.
There is no issue while installation.
But booting is failed. console_log.txt (66.7 KB)
So it is just like last second you are still able to mount sda1 but once you change “only” extlinux.conf on emmc, then next reboot cannot find sda1 anymore, is that what you are talking about?
Yes, you are right.
We used same process on JP4.6.2 over last 6 months. It was working correctly.
But it doesn’t work on JP5.0.2 as like what are we talk.
