Hi NVIDIA Jetson Community,
I’m excited to share my Autonomous Mobile Robot (AMR) built around the NVIDIA Jetson Orin Nano 8GB and ROS 2 Humble.
I started this project while learning ROS 2 and AI robotics, and gradually developed it into a complete physical robot integrating real-time computer vision, LiDAR-based obstacle avoidance, person following, autonomous behavior, voice interaction, vision-language capabilities, motor control, safety monitoring, and a web-based robot interface.
🤖 Autonomous Mobile Robot
The Jetson Orin Nano acts as the main computing platform and runs the robot’s perception, decision-making, interaction, and safety software.
An ESP32-C3 is used for low-level motor control and battery monitoring.
🚀 Key Features
YOLOv8n-Pose TensorRT inference on the Jetson GPU
Real-time person detection and tracking
Person-following behavior
Autonomous roaming and target search
RPLIDAR C1 based obstacle detection and reactive avoidance
Independent watchdog emergency-stop system
Voice commands using Faster-Whisper
GPU-enabled CTranslate2 for Speech-to-Text
Conversational AI using NVIDIA NIM
Vision-language interaction using an NVIDIA-hosted vision model
Offline Piper TTS
Raised-hand gesture control
ESP32-C3 motor and battery controller
Browser-based robot face / vision interface
Dockerized Jetson software environment
🧠 System Architecture
The robot uses a modular ROS 2 architecture divided mainly into:
Perception
camera_node -
detector_node -
tracking_node -
obstacle_detection_node
Control & Safety
decision_node -
motor_control_node -
watchdog_node -
display_node
Human-Robot Interaction
stt_node -
llm_node -
tts_node
The main data flow is:
Camera / LiDAR / Microphone → Perception → Decision → Motor Control → ESP32 → Motors
with a separate watchdog monitoring the system for safety-critical conditions.
⚡ NVIDIA Jetson Orin Nano
The project runs on an NVIDIA Jetson Orin Nano Developer Kit — 8GB.
For the final robot assembly, the Jetson is protected inside a metal enclosure. Photos of the bare Jetson, enclosure installation, and complete hardware build are available in the GitHub README.
Current vision pipeline
Camera: Waveshare IMX219-120 CSI
Capture: 1640 × 1232 @ 30 FPS
ROS processing stream: 640 × 480
Model: YOLOv8n-Pose
Runtime: TensorRT
Detector throughput: approximately 25–30 FPS
Typical inference latency: approximately 25–40 ms
🎙️ AI Interaction
The robot responds to the wake word:
“Vector”
and supports commands such as:
“Vector, follow me”
“Vector, stop”
“Vector, move forward”
“Vector, move backward”
“Vector, turn left/right”
“Vector, what do you see?”
“Vector, what is your battery status?”
The interaction pipeline uses:
USB Microphone → Faster-Whisper → CTranslate2 CUDA → NVIDIA NIM / Robot Command → Piper TTS → Speaker
The vision-language system can also analyze the current camera frame and answer scene-related questions.
✋ Gesture Control
YOLO pose keypoints are also used for simple human-robot gesture interaction.
A sustained left-hand raised gesture disables audio interaction and enables follow behavior, while a sustained right-hand raised gesture restores audio interaction.
🌐 Robot Web Interface
The robot includes a browser-based dashboard for:
Face mode
Vision mode
Audio ON/OFF
Robot connection status
Fullscreen operation
A screenshot of the interface is available in the GitHub README.
🐳 Docker Deployment
The complete Jetson software environment is containerized using Docker and NVIDIA Container Runtime.
The repository includes:
Dockerfile
ROS 2 Humble dependencies
Python dependencies
Jetson hardware access configuration
Faster-Whisper
Custom GPU-enabled CTranslate2 4.8.1 AArch64 build
Piper TTS
Build/run/test scripts
This allows the AMR environment to be reproduced on the target Jetson platform.
📊 Jetson Runtime
The full system was also monitored using NVIDIA tegrastats while the ROS 2 perception, LiDAR, control, speech, and hardware interfaces were active.
The runtime screenshot and additional performance details are available in the GitHub repository.
🎥 Demo Video
The full robot demonstration includes autonomous movement, person following, obstacle avoidance, voice interaction, vision interaction, gesture control, the web interface, Jetson hardware, and runtime monitoring.
🎥 Demo Video: Watch the full AMR demonstration on YouTube
💻 Source Code
The complete ROS 2 source code, ESP32 firmware, Docker environment, architecture documentation, and setup instructions are available on GitHub:
GitHub:
🛠️ Main Hardware
Waveshare IMX219-120 CSI Camera
SLAMTEC RPLIDAR C1
ESP32-C3 Super Mini
2 × BTS7960 motor drivers
4 × 12V DC geared motors
11.1V 6000mAh battery
USB microphone
Speaker
4WD mobile robot chassis
This project has been a practical learning journey in integrating ROS 2, NVIDIA Jetson, TensorRT, computer vision, embedded systems, autonomous robotics, and generative AI into a single physical robot.
Feedback and suggestions from the Jetson and robotics community are welcome.
Thank you!
