I’m currently trying to articulate a custom robot (UR10e + Robotiq 3-Finger Gripper) via the ros_bridge
. The robot is build upon another question of mine, see: Problems adding a gripper (Robotiq 3 Finger Gripper) to an UR10
It is also attached, see bottom.
Please also see my python script at the bottom, which I’m using to control the UR10. Alas, trying to control. It is also contained in the attached zip file.
I followed the ros_bridge guide and, as far as I can tell, I get the correct joint states via rostopic echo /joint_states
. Moreover, when I change the values for a joint in driver:angular:target
, the robot moves accordingly and the /joint_states
topic is updated. The driver:angular:targetType
is set to position for all joints.
Now my problem is that the robot is not moving when I run the script.
However, using the Franka as an example with the default script, it is working just fine.
I’m using Isaac Sim 2020.2_ea inside a docker with ros-melodic-ros-core
and the ROS workspace being build.
Any ideas?
Thank you,
Johann
Attachment: ur10_with_3f_gripper_ros_bridge.zip (18.6 KB)
#!/usr/bin/env python
import rospy
from sensor_msgs.msg import JointState
import numpy as np
import time
import argparse
parser = argparse.ArgumentParser()
parser.add_argument("--mode", help="indicate control mode")
args = parser.parse_args()
rospy.init_node("test_rosbridge", anonymous=True)
pub = rospy.Publisher("/joint_command", JointState, queue_size=10)
joint_state = JointState()
joint_state.name = [
"shoulder_pan_joint",
"shoulder_lift_joint",
"elbow_joint",
"wrist_1_joint",
"wrist_2_joint",
"wrist_3_joint",
"finger_middle_joint_1",
"finger_middle_joint_2",
"finger_middle_joint_3",
"palm_finger_1_joint",
"finger_1_joint_1",
"finger_1_joint_2",
"finger_1_joint_3",
"palm_finger_2_joint",
"finger_2_joint_1",
"finger_2_joint_2",
"finger_2_joint_3"
num_joints = len(joint_state.name)
# make sure kit's editor is playing for receiving messages ##
if args.mode == "position":
joint_state.position = np.array([0.0] * num_joints)
default_joints = [0.0, -1.5705, 0.0, 0.0, 0.0, 0.0, 0.05, 0.0, -0.05, 0.0, 0.05, 0.0, -0.05, 0.0, 0.05, 0.0, -0.05]
# limiting the movements to a smaller range (this is not the range of the robot, just the range of the movement
max_joints = np.array(default_joints) + 0.5
min_joints = np.array(default_joints) - 0.5
# position control the robot to wiggle around each joint
time_start = time.time()
rate = rospy.Rate(20)
while not rospy.is_shutdown():
joint_state.position = np.sin(time.time() - time_start) * (max_joints - min_joints) * 0.5 + default_joints
pub.publish(joint_state)
rate.sleep()
elif args.mode == "velocity":
rate = rospy.Rate(0.5)
joint_state.position = []
joint_state.velocity = np.array([-0.7] * num_joints)
rate.sleep()
joint_state.velocity = -joint_state.velocity
else:
print("control mode error")
