[ROS] Can I publish robot_description directly in IsaacSim?
Hi, I want to filter the robot motion from the published point cloud in Isaacsim.
Here is my setup.
PointCloud
Peek 2023-10-08 23-00
And I have attached the ActionGraph from the main.py code.
basically, /OmniIsaacRosBridge node publishes three topics, pointcloud2, tf_camera, and tf_every_robot_joint.
PointCloud filter
I want to use robot_body_filter, a ROS package that filters the robot and its shadow from the raw point cloud.
catkin_ws/src/robot_body_filter/launch/my_pcd_filter.launch
<launch>
    <node name="laser_filter" pkg="sensor_filters" type="pointcloud2_filter_chain">
        <rosparam command="load" file="$(dirname)/my_pcd_filter_config.yaml" />
        <remap from="~input" to="/Isaac/Depth_pcl" />
        <remap from="~output" to="/Isaac/Depth_pcl_filtered_bong" />
    </node>
</launch>
catkin_ws/src/robot_body_filter/launch/my_pcd_filter_config.yaml
cloud_filter_chain:
-   name: body_filter
    type: robot_body_filter/RobotBodyFilterPointCloud2
    params:
        frames/filtering: 'panda_link0'
        frames/output: 'Isaac_camera'
        sensor/min_distance: 0.05
        sensor/max_distance: 50.0
        body_model/inflation/scale: 1.1
        body_model/inflation/padding: 0.02
        filter/do_shadow_test: False
Question
I realized that RobotBodyFilter requires robot_description to compute the kinematics of the urdf_collision_mesh to filter processing.
$ roslaunch --screen robot_body_filter my_pcd_filter.launch
[ERROR] [1696769520.026045719]: RobotBodyFilter: robot_description is empty or not set. Please, provide the robot model. Waiting 1s.
But I have no idea how to publish robot_description directly from IsaacSim, which uses USD, not urdf file.
I would appreciate it if you could give me any advice. Thanks!
+This is a testbed for the real-world setup, so pcd segmentation is unfeasible.
Hi @PARKBONG,
Publishing the robot_description from IsaacSim is currently not supported at the moment. We will look into implementing this in a future release.
In the meantime you could try creating your own custom Python node to publish the robot description.
