Hi there,
I’m trying to build a ROS package which requires OpenCV using the “catkin_make” command.
Upon trying to build, I get the following error for CMakeList command “find_package(OpenCV REQUIRED)”:
CMake Error at /opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
Could not find a package configuration file provided by "OpenCV" with any of the following names:
OpenCVConfig.cmake
opencv-config.cmake
Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set "OpenCV_DIR" to a directory containing one of the above files.
I found the “OpenCVConfig.cmake” file at /usr/share/OpenCV/ and have set this location within the “OpenCV_DIR” env variable.
Despite this, I still get the error listed above.
Any ideas?
Myzhar
July 27, 2016, 5:19pm
2
Hi Will,
first of all you must verify that you have installed cv_bridge and image_geometry ROS packages on your machine.
sudo apt-get install ros-indigo-cv-bridge ros-indigo-image-geometry
Then try to recompile your node… if you are still getting the error try to follow my guide:
http://myzharbot.robot-home.it/blog/software/ros-nvidia-jetson-tx1-jetson-tk1-opencv-ultimate-guide/
Let me know
Walter
Thanks Walter!
Will give that a try tomorrow
I tried what you mentioned as well as following your blog post but it didn’t fix the issue, thanks anyway!
Myzhar
July 28, 2016, 11:50am
5
Are you sure that you have installed opencv4tegra on your system?
What do you get if you put “pkg-config --libs opencv”?
ubuntu@tegra-ubuntu:~/catkin_ws$ pkg-config --libs opencv
-L/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib -lopencv_calib3d -lopencv_contrib -lopencv_core -lopencv_features2d -lopencv_flann -lopencv_gpu -lopencv_highgui -lopencv_imgproc -lopencv_legacy -lopencv_ml -lopencv_objdetect -lopencv_photo -lopencv_stitching -lopencv_superres -lopencv_ts -lopencv_video -lopencv_videostab -lopencv_detection_based_tracker -lopencv_esm_panorama -lopencv_facedetect -lopencv_imuvstab -lopencv_tegra -lopencv_vstab -lcufft -lnpps -lnppi -lnppc -lcudart -ltbb -lrt -lpthread -lm -ldl
EDIT: fixed the problem by adding “set(OpenCV_DIR /usr/share/OpenCV/)” before the find_package() command in my cmakelists file
Myzhar
July 28, 2016, 1:11pm
7
I’m happy you solved it, but I cannot figure out why you need that command… I do not use it in my CMakeLists
odd! Thanks for all your help
q_bot
November 11, 2020, 11:30am
9
I am using the jetpack image on the sdk which is supposed to come with the opencv4tegra preinstalled.
My results for pkg-config --libs opencv4”:
bam@bam-desktop:~/catkin_ws/src/tests_cv$ pkg-config --libs opencv4
-lopencv_dnn -lopencv_gapi -lopencv_highgui -lopencv_ml -lopencv_objdetect -lopencv_photo -lopencv_stitching -lopencv_video -lopencv_calib3d -lopencv_features2d -lopencv_flann -lopencv_videoio -lopencv_imgcodecs -lopencv_imgproc -lopencv_core
I still get the same error even when I add the
set(OpenCV4_DIR /usr/share/OpenCV4/)”
before my CMakeLists
The opencv version installed is opencv4.
I am building a completely new package with dependency on opencv4
