Ros jetson_camera/raw image is only black
why image take from node jetson camera/raw only is black image? , this in jetson nano
Hi snek_angel15,
Please elaborate more details of your device system setup, such as BSP version, camera setup, capture command line…etc.
Hi kayccc
JetPack 4.2.2 jetson nano kit
Csi raspberry pi camera
ROS version: MELODIC
From the jetbot_ros package, i ran the jetbot_camera node and subscribed to the jetbot_camera/raw topic with $ rosrun image_view image_view image:=/jetbot_camera/raw, and the image was black.
Could you check if nvgstcapture-1.0 can show the camera preview first.
Hi snek_angel15, I just made some fixes to the jetbot_ros repo, sorry about that. Please remove it from your catkin workspace and re-clone.
You should be able to view the /jetbot_camera/raw topic now.
Also, I added some instructions for viewing the video feed here: https://github.com/dusty-nv/jetbot_ros#using-the-camera
Hello, I’m having the same issue even after removing and re-cloning jetbot_ros. I am using a Sparkfun JetBot. In order to view the camera stream, I used the instructions provided here under the section titled ‘Using the Camera’, but I only receive a black window when running the line ‘rosrun image_view image_view image:=/jetbot_camera/raw’.
As I mentioned, I re-cloned jetbot_ros, and during the build using catkin_make, I noticed some messages that may point to the issue (see below or screenshot link here). Are there possibly still some fixes needed in the jetbot_ros repo?
Scanning dependencies of target jetbot_camera
[  6%] Building CXX object jetbot_ros/CMakeFiles/jetbot_camera.dir/src/jetbot_camera.cpp.o
/home/jetbot/workspace/catkin_ws/src/jetbot_ros/src/jetbot_camera.cpp: In function ‘bool aquireFrame()’:
/home/jetbot/workspace/catkin_ws/src/jetbot_ros/src/jetbot_camera.cpp:47:15: error: ‘class gstCamera’ has no member named ‘CaptureRGBA’; did you mean ‘Capture’?
  if( !camera->CaptureRGBA(&imgRGBA, 1000) )
               Capture
/home/jetbot/workspace/catkin_ws/src/jetbot_ros/src/jetbot_camera.cpp: In function ‘int main(int, char**)’:
/home/jetbot/workspace/catkin_ws/src/jetbot_ros/src/jetbot_camera.cpp:97:48: error: invalid conversion from ‘const char*’ to ‘int’ [-fpermissive]
  camera = gstCamera::Create(camera_device.c_str());
In file included from /home/jetbot/workspace/catkin_ws/src/jetbot_ros/src/jetbot_camera.cpp:28:0:
/usr/local/include/jetson-utils/gstCamera.h:57:20: note:   initializing argument 1 of ‘static gstCamera* gstCamera::Create(int)’
  static gstCamera* Create( int v4l2_device=-1 ); // use onboard camera by default (>=0 for V4L2)
jetbot_ros/CMakeFiles/jetbot_camera.dir/build.make:62: recipe for target 'jetbot_ros/CMakeFiles/jetbot_camera.dir/src/jetbot_camera.cpp.o' failed
make[2]: *** [jetbot_ros/CMakeFiles/jetbot_camera.dir/src/jetbot_camera.cpp.o] Error 1
CMakeFiles/Makefile2:615: recipe for target 'jetbot_ros/CMakeFiles/jetbot_camera.dir/all' failed
make[1]: *** [jetbot_ros/CMakeFiles/jetbot_camera.dir/all] Error 2
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j2 -l2" failed
On ros meodic I used a apt install of usb_cam - rqt works with a Asus Xtion camera, (usb_cam test launch) but fails with a raspicam. I see the usb_cam/image_raw topic, but rqt_image doesn’t list this topic. is this a transform issue? also the usb_cam launch throws a usc_cam/node not found error. (OpenCV4?)
Could you explain how you achieved this? I want to also use the Asus Xtion Pro camera on the Jetson Nano…I’m wondering, were you able to obtain the RGB and Depth images? I haven’t found much information on the topic so I would appreciate your help. Thanks!
