Hi
I am adding the following line to .bashrc on Pegasus system:
–>>> source /opt/ros/melodic/setup.bash
After login and trying to run roscore I got the following error:
nvidia@tegra-ubuntu:~$ roscore
… logging to /home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/roslaunch-tegra-ubuntu-26388.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://tegra-ubuntu:40257/
ros_comm version 1.14.10
SUMMARY
PARAMETERS
- /rosdistro: melodic
- /rosversion: 1.14.10
NODES
auto-starting new master
process[master]: started with pid [26398]
ROS_MASTER_URI=http://tegra-ubuntu:11311/
setting /run_id to 0d82d504-4078-11eb-8876-00044bf65e6e
/opt/ros/melodic/lib/rosout/rosout: error while loading shared libraries: libroscpp.so: cannot open shared object file: No such file or directory
process[rosout-1]: started with pid [26409]
started core service [/rosout]
[rosout-1] process has died [pid 26409, exit code 127, cmd /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log].
log file: /home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1*.log
[rosout-1] restarting process
failed to start local process: /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log
process[rosout-1]: started with pid [26413]
[rosout-1] process has died [pid 26413, exit code 127, cmd /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log].
process[rosout-1]: started with pid [26415]
[rosout-1] process has died [pid 26415, exit code 127, cmd /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log].
process[rosout-1]: started with pid [26416]
[rosout-1] process has died [pid 26416, exit code 127, cmd /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log].
process[rosout-1]: started with pid [26417]
[rosout-1] process has died [pid 26417, exit code 127, cmd /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log].
process[rosout-1]: started with pid [26418]
[rosout-1] process has died [pid 26418, exit code 127, cmd /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log].
process[rosout-1]: started with pid [26419]
[rosout-1] process has died [pid 26419, exit code 127, cmd /opt/ros/melodic/lib/rosout/rosout __name:=rosout __log:=/home/nvidia/.ros/log/0d82d504-4078-11eb-8876-00044bf65e6e/rosout-1.log].
^Cprocess[rosout-1]: started with pid [26420]
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor…
… shutting down processing monitor complete
done
But if I source .bashrc and run roscore after login, I don’t see the issue.
Any suggestions to fix this issue?
