I am currently working on a Jetson TX2 for a drone project. I am trying to run ROS (melodic or noetic) and Tensorflow with python3. I want to use an IntelRealsense camera, feed the stream to a neural network on TensorFlow, and manage everything else like communication, perception, control, and planning on ROS.
So far I have tried different approaches but couldn’t find a proper one where everything works together.
Standard ROS melodic installation did not work because it comes with python2.7.
Used the ros-noetic docker image from dusty-nv since it comes with python3 but the installation steps for TensorFlow on Nvidia documentation did not work in docker.
Built a docker container using the ROS-noetic base image from dusty-nv and inside the container built Tensorflow from source. This worked but then I tried to install additional ros packages like librealsense2 and it didn’t work. I figured out that I need to build everything additional from source and e.g. cv-bridge did not work. This solution may cause a lot of problems in the future steps of the development, the docker container gets very big in size and already caused memory issues.
Made a release update to Ubuntu 20.04 but it comes with python3.8 and the whl files to install TensorFlow are for python 3.6. I built python 3.6 from source and managed to run TensorFlow but then faced a problem with catkin tools once switched to python3.6.
Or you could also do it the other way around - change the base of the ROS Noetic container to my pre-built l4t-tensorflow container, and rebuild the Noetic container. This is what I do for the ros:pytorch containers, I build those on top of l4t-pytorch.
@yumurta
4. it should be possible to adjust the approach to get it working, in my opinion. However, there are two possible directions: to approach : A) OS upgrade to 20.04 systemwide or B) OS upgrade to 20.04 withing a container, without upgrading the OS systemwide
Probably I did not use that particular docker image you are using but highly likely it should be possible to setup ros realsense packages. They are typically compatible with certain realsense sdk versions which need to be installed separately so specific version of ros package from realsense may require specific realsense sdk version installed. I would j also try using the default l4t base or tensorflow ngc container then add ros to there.
If I were you I would rather build a docker container based on ngc l4t tensorflow with adding steps for installing melodic/noetic/foxy whatever is required
