ROS1 and ROS2 on Target
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.3.10426
other
Host Machine Version
native Ubuntu 18.04
other
is it possible to run ROS2 on the target or is only ROS1 supported?
Thanks in advance.
We had tried ROS1 before but the releases don’t support ROS officially.
Does this mean that you were already able to run ROS on the Pegasus platform? Was it ROS1 or ROS2?
It’s ROS1. Please refer to https://developer.nvidia.com/blog/cross-compiling-robot-operating-system-nodes-for-nvidia-drive-agx/.
Is it possible to execute DNNs such as PathNet in a ROS Node? Do you have any experience with this`or have you done this in the past?
We haven’t worked on DRIVE Perception on ROS.
yes, you can. You must read image and convert to dwImageCUDA, and use sample code of pathnet (initDetector, initRigConfiguration and onProcess, etc.) and you must compile with dw
thanks for the reply!
Is this also possible in ROS2? Do you have any experience in doing this in ROS2?
I not try ros2 in drive, only ros1
