Everything worked until the section ‘running-nav2’:
When I hit play again, rviz wont open and when I try to execute the command:
ros2 launch carter_navigation carter_navigation.launch.py
I get the following error:
`Caught exception when trying to load file of format [py]: "package 'nav2_bringup' not found, searching: ['/home/schmi/ros2_ws/install/isaac_ros2_messages', '/home/schmi/ros2_ws/install/carter_navigation', '/home/schmi/ros2_ws/install/carter_description', '/home/schmi/ros2_foxy/ros2-linux']"`
Why is it searching for a package ''nav2_bringup" in my workspace?
