I have gone through many forums but no one provides a clarified way to install ROS2 Humble in NVIDIA Jetson Nano.
I purchased Jetson Nano in 2020 and only used a little then. Now I again started development using Jetson Nano (Building an Autonomous Mobile Robot) and I need ROS2 Humble in Jetson Nano as my whole project is based on it only (in my Ubuntu). I completely relied upon the Jetson Nano as the onboard computer for my robot but when I started integrating the Hardware (after completing the simulation), I was completely dumb!! , that there is no proper resource available to install ROS2 in Jetson Nano.
I dig out a lot in the discussion forums and none of them provide proper clarification. Some say to use docker but I don’t have any experience using docker and I don’t want to go with the method to install ROS2 Humble using Docker Container as the configuration will take a long time.
As NVIDIA has declared (the worst thing I have seen from NVIDIA) Jetson Nano doesn’t support JetPack 5 and ROS2 requires JetPack 5. This is completely a failure of NVIDIA.
Nano is itself a quite expensive board and it’s not possible to invest another $500 bucks to buy a new board.
I’m seeking help from the community. Please provide some help about How can I install ROS2 Humble in Jetson Nano.
One more question I have, Is it possible to install core Ubuntu installation in Jetson Nano instead of installing using JetPack? If yes, which version of Ubuntu is supported?
