ROS2 | LaserScan faulty data
Currently, when there is nothing in front of the lidar, it will publish ranges with the max_range param as its value. Existing ROS2 algorithms are expecting inf in such a case. This specifically breaks slam_toolbox.
For example, our max_range is 2 meters. This is the message from Issac Sim:
ranges:
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
- 2.0
This is the same message from Gazebo:
ranges:
- .inf
- .inf
- .inf
- .inf
- .inf
- .inf
- .inf
- .inf
- .inf
- .inf
- .inf
- .inf
Gazebo’s message works perfectly fine, while the one from Isaac Sim is causing bad TF transformations.
Hi - Sorry for the delay in the response. Let us know if you still having this issue with the latest Isaac Sim 2022.2.1 release.
