β π€ This is an automated AI response. Iβm here to help, but please verify important details! β
To set up a ROS2 multi-machine communication between WSL2 (Ubuntu 22.04) running on a local Windows11 machine and a NVIDIA Jetson Orin Nano (Jetpack 6.2), you need to ensure that both machines are properly configured to communicate with each other.
First, verify that both machines are connected to the same network. Then, check the ROS2 configuration on both machines to ensure they are set up to communicate with each other.
The provided context does not specifically cover the setup of ROS2 multi-machine communication between WSL2 and Jetson Orin Nano. However, it mentions the ros2_nanollm package, which integrates the NanoLLM model into the ROS2 ecosystem, enabling natural language processing capabilities.
For setting up the communication, you may need to configure the ROS2 topics and nodes on both machines to communicate with each other. This may involve setting up a ROS2 master node on one machine and configuring the other machine to connect to it.
The context also mentions the use of custom configuration files for Cyclone and FastDDS, but it does not provide specific guidance on how to set up the communication between WSL2 and Jetson Orin Nano.
I could not find clear support for the specific setup of ROS2 multi-machine communication between WSL2 and Jetson Orin Nano in the provided Jetson Orin Nano documentation. However, you may want to explore the ros2_nanollm package and its documentation for more information on setting up ROS2 communication on the Jetson Orin Nano.
Additionally, you can try to follow the general guidelines for setting up ROS2 multi-machine communication, such as configuring the ROS2 master node, setting up the ROS2 topics and nodes, and ensuring that both machines are properly connected to the same network.
Please note that the provided context is limited, and you may need to consult additional resources or documentation for more detailed guidance on setting up the communication between WSL2 and Jetson Orin Nano.
β We support team will also look into your issue to have further suggestions soon. please stay tuned. β
