ROS2 Nav Global Map Offset Issues & Navigation Goal Issues
Isaac Sim Version
[ X] 4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
ROS2 Foxy
Topic Description
Detailed Description
I am trying to run the Isaac Sim ROS2 Navigation Goals example in a custom environment and am running into various issues.
When I replicate the example using a custom environment, the global map in Rviz is off-centre. This is not an issue when setting a navigation goal within Rviz, but when I set a goal in the txt file and run isaac_ros_navigation_goal the robot just spins in place. I have edited the initial pose in the param.yaml file to fit the new environment, but that makes no difference as the global map is offset. I have also updated the map.yaml file and map.png file for the custom environment.
In addition, when running the example in the custom environment I get the following warning:
[rviz2]: Message Filter dropping message: frame 'odom' at time 354.950 for reason 'Unknown'
I’ve ran ros2 run tf2_tools view_frames.py and compared the frames.pdf for both the original example and my custom version and there is no difference between them.
I would like to be able to set up a navigation goals simulation in a custom environment, so would be grateful for any help with this. Thank you!
Hey @christmas_robot! Do you mind sharing your USD file (as collective if there are any references) so we can try to reproduce your issue?
I will close this topic since there is no new replies. But please feel free to open a new topic if the issue persists.
