I am using Ubuntu 22.04 with ROS2 Humble along with Isaac Sim 2023.1.0.
The ROS2 Navigation example provided in the Isaac Examples does not load completely for me.
for your reference, I have attached the error/warning messages that pop up on terminal when I try to load the ROS Navigation example:
[11.002s] Isaac Sim App is loaded.
server omniverse://localhost: ConnectionStatus.CONNECTING
server omniverse://localhost: ConnectionStatus.CONNECTED
server omniverse://isaac-dev.ov.nvidia.com: ConnectionStatus.CONNECTING
server omniverse://isaac-dev.ov.nvidia.com: ConnectionStatus.CONNECT_ERROR
2023-10-26 06:26:45 [172,503ms] [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp -- In </World/warehouse_extras>: Could not open asset @omniverse://isaac-dev.ov.nvidia.com/Isaac/Environments/Simple_Warehouse/Stage/warehouse_extras.usd@ for reference introduced by @omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.0/Isaac/Samples/ROS2/Scenario/carter_warehouse_navigation.usd@</World/warehouse_extras>. (instantiating stage on stage @omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.0/Isaac/Samples/ROS2/Scenario/carter_warehouse_navigation.usd@ <0x7f1c6c01bb30>)
2023-10-26 06:26:45 [172,503ms] [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp -- In </World/warehouse_with_forklifts>: Could not open asset @omniverse://isaac-dev.ov.nvidia.com/Isaac/Environments/Simple_Warehouse/warehouse_with_forklifts.usd@ for reference introduced by @omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.0/Isaac/Samples/ROS2/Scenario/carter_warehouse_navigation.usd@</World/warehouse_with_forklifts>. (instantiating stage on stage @omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.0/Isaac/Samples/ROS2/Scenario/carter_warehouse_navigation.usd@ <0x7f1c6c01bb30>)
2023-10-26 06:26:45 [172,582ms] [Warning] [omni.timeline.plugin] Deprecated: direct use of ITimeline callbacks is deprecated. Use ITimeline::getTimeline (Python: omni.timeline.get_timeline_interface) instead.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/wheel_right/Cylinder_05 is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/wheel_right/Cylinder_04 is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/wheel_left/Cylinder_02 is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/wheel_left/Cylinder is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/wheel_left/Cylinder_01 is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/caster_wheel_right/Cylinder_06 is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/wheel_right/Cylinder_03 is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:45 [172,753ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/Carter_v2_4_ROS/Carter_V24/caster_wheel_left/Cylinder_07 is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2023-10-26 06:26:50 [178,237ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling getBypassRenderSkelMeshProcessing for prim /World/Carter_v2_4_ROS/Carter_V24/chassis_link/Carter_Sen_Pos_Ctrl_Doc/Robot_Volume.proto_Robot_Volume_id0 that has not been populated
2023-10-26 06:26:57 [184,819ms] [Warning] [carb] Client omni.ui has acquired [carb::svg::Svg v0.1] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2023-10-26 06:26:57 [184,820ms] [Warning] [carb] Client omni.ui has acquired [omni::kit::renderer::IRenderer v1.9] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2023-10-26 06:31:12 [440,000ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp -- In </World/warehouse_with_forklifts>: Could not open asset @omniverse://isaac-dev.ov.nvidia.com/Isaac/Environments/Simple_Warehouse/warehouse_with_forklifts.usd@ for reference introduced by @omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.0/Isaac/Samples/ROS2/Scenario/carter_warehouse_navigation.usd@</World/warehouse_with_forklifts>. (computing expanded prim index for </World/warehouse_with_forklifts> on stage @omniverse://localhost/NVIDIA/Assets/Isaac/2023.1.0/Isaac/Samples/ROS2/Scenario/carter_warehouse_navigation.usd@ <0x7f1c6c01bb30>)
