Hello may I know, can I read point cloud from Ros from other model of velodyne or other than velodyne 16 using Isaac Rosbridge.? Thanks
The message schema from the ROS Velodyne nodes should be the same for different models of the Velodyne lidars so ROSbridge should work fine. You can always implement your own ROSbridge too.
