Rror getting vGPU config: error getting all vGPU devices: unable to read MDEV devices directory: open /sys/bus/mdev/devices: no such file or directory
Hello -
I’m trying to enable vGPUs on OpenShift 4.11 following these docs NVIDIA GPU Operator with OpenShift Virtualization — gpu-operator 23.6.1 documentation
oc get pods -n nvidia-gpu-operator
NAME                               READY   STATUS     RESTARTS   AGE
gpu-operator-fbb6ffcc8-gzddt       1/1     Running    0          4h56m
nvidia-vgpu-device-manager-2b5r5   1/1     Running    0          13m
nvidia-vgpu-device-manager-f4rnr   0/1     Init:0/1   0          12m
nvidia-vgpu-device-manager-knx9v   0/1     Init:0/1   0          12m
Current error, which probably means it can’t find this device from the config file https://github.com/NVIDIA/vgpu-device-manager/blob/main/examples/config-example.yaml#L1848
oc logs -f nvidia-vgpu-device-manager-2b5r5
Defaulted container "nvidia-vgpu-device-manager" out of: nvidia-vgpu-device-manager, vgpu-manager-validation (init)
W0926 20:19:37.905184       1 client_config.go:617] Neither --kubeconfig nor --master was specified.  Using the inClusterConfig.  This might not work.
time="2023-09-26T20:19:37Z" level=info msg="Updating to vGPU config: RTXA5000-1Q"
time="2023-09-26T20:19:37Z" level=info msg="Asserting that the requested configuration is present in the configuration file"
time="2023-09-26T20:19:37Z" level=info msg="Selected vGPU device configuration is valid"
time="2023-09-26T20:19:37Z" level=info msg="Checking if the selected vGPU device configuration is currently applied or not"
time="2023-09-26T20:19:37Z" level=fatal msg="Assertion failure: selected configuration not currently applied"
time="2023-09-26T20:19:37Z" level=info msg="Getting current value of 'nvidia.com/gpu.deploy.sandbox-device-plugin' node label"
time="2023-09-26T20:19:37Z" level=info msg="Current value of 'nvidia.com/gpu.deploy.sandbox-device-plugin=paused-for-vgpu-change'"
time="2023-09-26T20:19:37Z" level=info msg="Getting current value of 'nvidia.com/gpu.deploy.sandbox-validator' node label"
time="2023-09-26T20:19:37Z" level=info msg="Current value of 'nvidia.com/gpu.deploy.sandbox-validator=paused-for-vgpu-change'"
time="2023-09-26T20:19:37Z" level=info msg="Getting current value of 'nvidia.com/vgpu.config.state' node label"
time="2023-09-26T20:19:37Z" level=info msg="Current value of 'nvidia.com/vgpu.config.state=failed'"
time="2023-09-26T20:19:37Z" level=info msg="Changing the 'nvidia.com/vgpu.config.state' node label to 'pending'"
time="2023-09-26T20:19:37Z" level=info msg="Shutting down all GPU operands in Kubernetes by disabling their component-specific nodeSelector labels"
time="2023-09-26T20:19:38Z" level=info msg="Waiting for sandbox-device-plugin to shutdown"
time="2023-09-26T20:19:38Z" level=info msg="Waiting for sandbox-validator to shutdown"
time="2023-09-26T20:19:38Z" level=info msg="Applying the selected vGPU device configuration to the node"
time="2023-09-26T20:19:38Z" level=debug msg="Parsing config file..."
time="2023-09-26T20:19:38Z" level=debug msg="Selecting specific vGPU config..."
time="2023-09-26T20:19:38Z" level=debug msg="Checking current vGPU device configuration..."
time="2023-09-26T20:19:38Z" level=debug msg="Walking VGPUConfig for (devices=all)"
time="2023-09-26T20:19:38Z" level=debug msg="  GPU 0: 0x223110DE"
time="2023-09-26T20:19:38Z" level=info msg="Applying vGPU device configuration..."
time="2023-09-26T20:19:38Z" level=fatal msg="error getting vGPU config: error getting all vGPU devices: unable to read MDEV devices directory: open /sys/bus/mdev/devices: no such file or directory"
time="2023-09-26T20:19:38Z" level=info msg="Changing the 'nvidia.com/vgpu.config.state' node label to 'failed'"
time="2023-09-26T20:19:38Z" level=error msg="ERROR: unable to apply config 'RTXA5000-1Q': exit status 1"
time="2023-09-26T20:19:38Z" level=info msg="Waiting for change to 'nvidia.com/vgpu.config' label"
I do have 2 different GPUs RTX5000 and A100. The deployment get stuck on the RXT5000 and doesn’t continue to try to configure the rest of the nodes.
The nodes containing A100, I have set a label nvidia.com/vgpu.config=A10-3Q and accordingly RXT5000 I have set nvidia.com/vgpu.config=RTXA5000-1Q.
clusterpolicy config
apiVersion: nvidia.com/v1
kind: ClusterPolicy
metadata:
  creationTimestamp: '2023-09-26T19:59:16Z'
  generation: 1
  managedFields:
    - apiVersion: nvidia.com/v1
      fieldsType: FieldsV1
      fieldsV1:
        'f:status':
          'f:namespace': {}
          'f:state': {}
      manager: Go-http-client
      operation: Update
      subresource: status
      time: '2023-09-26T19:59:16Z'
      fieldsV1:
        'f:spec':
          'f:gds':
            'f:enabled': {}
          'f:vgpuManager':
            'f:driverManager':
              'f:image': {}
              'f:repository': {}
              'f:version': {}
            'f:enabled': {}
          'f:vfioManager':
            'f:enabled': {}
          'f:daemonsets':
            'f:rollingUpdate':
              'f:maxUnavailable': {}
            'f:updateStrategy': {}
          'f:sandboxWorkloads':
            'f:defaultWorkload': {}
            'f:enabled': {}
          'f:nodeStatusExporter':
            'f:enabled': {}
          'f:toolkit':
            'f:enabled': {}
            'f:installDir': {}
          'f:vgpuDeviceManager':
            'f:config':
              'f:default': {}
            'f:enabled': {}
          'f:gfd':
            'f:enabled': {}
          'f:cdi':
            'f:default': {}
            'f:enabled': {}
          'f:migManager':
            'f:config':
              'f:default': {}
              'f:name': {}
            'f:enabled': {}
          'f:kataManager':
            'f:config':
              'f:artifactsDir': {}
          'f:mig':
            'f:strategy': {}
          'f:operator':
            'f:defaultRuntime': {}
            'f:initContainer': {}
            'f:runtimeClass': {}
            'f:use_ocp_driver_toolkit': {}
          'f:dcgm':
            'f:enabled': {}
          'f:dcgmExporter':
            'f:config':
              'f:name': {}
            'f:enabled': {}
            'f:serviceMonitor':
              'f:enabled': {}
          'f:sandboxDevicePlugin':
            'f:enabled': {}
          'f:driver':
            'f:certConfig':
              'f:name': {}
            'f:enabled': {}
            'f:kernelModuleConfig':
              'f:name': {}
            'f:licensingConfig':
              'f:configMapName': {}
              'f:nlsEnabled': {}
            'f:repoConfig':
            'f:upgradePolicy':
              'f:autoUpgrade': {}
              'f:drain':
                'f:deleteEmptyDir': {}
                'f:enable': {}
                'f:force': {}
                'f:timeoutSeconds': {}
              'f:maxParallelUpgrades': {}
              'f:podDeletion':
                'f:force': {}
              'f:waitForCompletion':
            'f:virtualTopology':
              'f:config': {}
          'f:devicePlugin':
            'f:config':
              'f:default': {}
              'f:name': {}
            'f:enabled': {}
          'f:validator':
            'f:plugin':
              'f:env': {}
      manager: kubectl-create
      operation: Update
  resourceVersion: '387476060'
  uid: 34ea9517-1d7a-44b1-b7af-b84db66615a7
spec:
  vgpuDeviceManager:
    config:
      default: default
    enabled: true
  migManager:
    config:
      default: all-disabled
    enabled: true
  operator:
    defaultRuntime: crio
    initContainer: {}
    runtimeClass: nvidia
    use_ocp_driver_toolkit: true
  dcgm:
    enabled: true
  gfd:
    enabled: true
  dcgmExporter:
    config:
    enabled: true
    serviceMonitor:
      enabled: true
  cdi:
    default: false
    enabled: false
  driver:
    certConfig:
    enabled: true
    kernelModuleConfig:
    licensingConfig:
      configMapName: licensing-config
      nlsEnabled: true
    repoConfig:
      configMapName: ''
    upgradePolicy:
      autoUpgrade: true
      drain:
        deleteEmptyDir: false
        enable: false
        force: false
        timeoutSeconds: 300
      maxParallelUpgrades: 1
      maxUnavailable: 25%
      podDeletion:
        force: false
        timeoutSeconds: 300
      waitForCompletion:
        timeoutSeconds: 0
    virtualTopology:
      config: ''
  devicePlugin:
    config:
      default: ''
    enabled: true
  kataManager:
    config:
      artifactsDir: /opt/nvidia-gpu-operator/artifacts/runtimeclasses
  mig:
    strategy: single
  sandboxDevicePlugin:
    enabled: true
  validator:
    plugin:
      env:
        - name: WITH_WORKLOAD
          value: 'false'
  nodeStatusExporter:
    enabled: true
  daemonsets:
    rollingUpdate:
      maxUnavailable: '1'
    updateStrategy: RollingUpdate
  sandboxWorkloads:
    defaultWorkload: vm-vgpu
    enabled: true
  gds:
    enabled: false
  vgpuManager:
    driverManager:
      image: vgpu-manager
      repository: default-route-openshift-image-registry.apps.ocp4.poc.site/pp-testing
      version: 535.104.06-rhcos4.11
    enabled: true
  vfioManager:
    enabled: true
  toolkit:
    enabled: true
    installDir: /usr/local/nvidia
status:
  namespace: nvidia-gpu-operator
  state: notReady
I can see the GPUs on the physical nodes
oc debug node/gpu1  -- chroot /host lspci -nnk -d 10de:
Starting pod/gpu1ocp4pocsite-debug ...
To use host binaries, run `chroot /host`
0000:31:00.0 VGA compatible controller [0300]: NVIDIA Corporation GA102GL [RTX A5000] [10de:2231] (rev a1)
	Subsystem: NVIDIA Corporation Device [10de:147e]
	Kernel driver in use: nvidia
	Kernel modules: nouveau
oc debug node/gpu3 -- chroot /host lspci -nnk -d 10de:
Starting pod/gpu3ocp4pocsite-debug ...
1b:00.0 3D controller [0302]: NVIDIA Corporation GA100 [A100 PCIe 80GB] [10de:20b5] (rev a1)
	Subsystem: NVIDIA Corporation Device [10de:1533]
1c:00.0 3D controller [0302]: NVIDIA Corporation GA100 [A100 PCIe 80GB] [10de:20b5] (rev a1)
Any help?
My device manager pod is in the same state vGPU device manager pod stuck in init container phase · Issue #554 · NVIDIA/gpu-operator · GitHub
I removed this labelnvidia.com/vgpu.config and let the default configuration to take over.
I also label my RTX5000 GPU to be pass-through using oc label node gpu1 --overwrite nvidia.com/gpu.workload.config=vm-passthrough and this GPU get successfully recognized
oc logs -f nvidia-vfio-manager-dhpxj
Defaulted container "nvidia-vfio-manager" out of: nvidia-vfio-manager, k8s-driver-manager (init)
binding device 0000:31:00.0
binding device 0000:31:00.1
But the rest two nodes that are intended for vm-vgpu or vGPU usage are stuck.
oc logs -f nvidia-vgpu-device-manager-hmqjt -c vgpu-manager-validation
waiting for NVIDIA vGPU Manager to be setup
^C
oc logs -f nvidia-vgpu-device-manager-q8khn  -c vgpu-manager-validation
^C
If I disable sandboxWorloads.enabled option the the GPUs are getting recognized, but the vGPU configuration fails nvidia.com/vgpu.config.state=failed
oc describe node gpu4 | grep -i nvidia.com
                    nvidia.com/cuda.driver.major=535
                    nvidia.com/cuda.driver.minor=104
                    nvidia.com/cuda.driver.rev=05
                    nvidia.com/cuda.runtime.major=12
                    nvidia.com/cuda.runtime.minor=2
                    nvidia.com/gfd.timestamp=1695828096
                    nvidia.com/gpu-driver-upgrade-state=upgrade-done
                    nvidia.com/gpu.compute.major=8
                    nvidia.com/gpu.compute.minor=0
                    nvidia.com/gpu.count=2
                    nvidia.com/gpu.deploy.container-toolkit=true
                    nvidia.com/gpu.deploy.dcgm=true
                    nvidia.com/gpu.deploy.dcgm-exporter=true
                    nvidia.com/gpu.deploy.device-plugin=true
                    nvidia.com/gpu.deploy.driver=true
                    nvidia.com/gpu.deploy.gpu-feature-discovery=true
                    nvidia.com/gpu.deploy.mig-manager=true
                    nvidia.com/gpu.deploy.node-status-exporter=true
                    nvidia.com/gpu.deploy.nvsm=
                    nvidia.com/gpu.deploy.operator-validator=true
                    nvidia.com/gpu.family=ampere
                    nvidia.com/gpu.machine=G292-280-IAY1-000
                    nvidia.com/gpu.memory=81920
                    nvidia.com/gpu.present=true
                    nvidia.com/gpu.product=NVIDIA-A100-80GB-PCIe
                    nvidia.com/gpu.replicas=1
                    nvidia.com/gpu.workload.config=vm-vgpu
                    nvidia.com/mig.capable=true
                    nvidia.com/mig.config=all-disabled
                    nvidia.com/mig.config.state=success
                    nvidia.com/mig.strategy=single
                    **nvidia.com/vgpu.config.state=failed**
                    nvidia.com/gpu-driver-upgrade-enabled: true
  nvidia.com/A100:                 0
  nvidia.com/gpu:                  2
  nvidia.com/A100:                 0
  nvidia.com/gpu:                  2
  nvidia.com/A100                 1             1
  nvidia.com/gpu                  0             0
The error message sounds like the Mediated Devices feature is not enabled.
Probably a silly question, but have you enabled the IOMMU driver on the host?
This is documented here: NVIDIA GPU Operator with OpenShift Virtualization — gpu-operator 23.6.1 documentation.
Note that the kernel argument for AMD is “amd_iommu=on”.
Yes we have the intel_iommu=on enabled.
Hello to both of you @ppetkov12 and @fdupont and welcome to the NVIDIA developer forums.
I am not the expert on vGPU and I think you will have better success getting some suggestions if you post in our dedicated vGPU forums.
If you don’t mind, I can move this whole topi over there for you?
I am just not sure if it is a better fit for General discussion or rather the driver category?
Any preference?
Sounds good to me. Thank you.
Sounds good.
I had the same issue. I had the following labels on my two workers with A40 cards:
nvidia.com/gpu.deploy.sandbox-device-plugin=paused for vgpu change
nvidia.com/gpu.deploy.sandbox-validator=paused for vgpu change
I manually changed the label to true and the vgpu-device-manager came up
