While testing dpdk(v19.11.10) application we noticed that nic card didn’t update mbuf.hash.rss value despite the fact that rxmode.mq_mode = ETH_MQ_RX_RSS_FLAG was set.
Is there any other way to enable RSS on the card ?
here is additional info :
DPDK RSS offload enable code:
static struct rte_eth_conf port_conf = {
.rxmode = {
.mq_mode = ETH_MQ_RX_RSS | ETH_MQ_RX_RSS_FLAG,
.max_rx_pkt_len = RTE_ETHER_MAX_LEN,
.offloads = DEV_RX_OFFLOAD_RSS_HASH,
.rx_adv_conf = {
.rss_conf = {
.rss_key = NULL
.rss_hf = ETH_RSS_IP | ETH_RSS_UDP | ETH_RSS_TCP,
.txmode = {
.mq_mode = ETH_MQ_TX_NONE,
.offloads = DEV_TX_OFFLOAD_IPV4_CKSUM | DEV_TX_OFFLOAD_TCP_CKSUM | DEV_TX_OFFLOAD_UDP_CKSUM,
Card firmware:
flint -d /dev/mst/mt4125_pciconf0 query
Image type: FS4
FW Version: 22.32.1010
FW Release Date: 1.12.2021
Product Version: 22.32.1010
Rom Info: type=UEFI version=14.25.17 cpu=AMD64,AARCH64
type=PXE version=3.6.502 cpu=AMD64
Description: UID GuidsNumber
Base GUID: 08c0eb030059cd20 4
Base MAC: 08c0eb59cd20 4
Image VSD: N/A
Device VSD: N/A
PSID: MT_0000000359
Security Attributes: N/A
lspci output:
07:00.0 Ethernet controller [0200]: Mellanox Technologies MT28841 [15b3:101d]
Subsystem: Mellanox Technologies MT28841 [15b3:0016]
Physical Slot: 2
Flags: bus master, fast devsel, latency 0, IRQ 93, NUMA node 0
Memory at f4000000 (64-bit, prefetchable) [size=32M]
[virtual] Expansion ROM at ec100000 [disabled] [size=1M]
Capabilities: [60] Express Endpoint, MSI 00
Capabilities: [48] Vital Product Data
Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
Capabilities: [c0] Vendor Specific Information: Len=18 <?>
Capabilities: [40] Power Management version 3
Capabilities: [100] Advanced Error Reporting
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [180] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1c0] #19
Capabilities: [230] Access Control Services
Capabilities: [320] #27
Capabilities: [370] #26
Capabilities: [420] #25
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
07:00.1 Ethernet controller [0200]: Mellanox Technologies MT28841 [15b3:101d]
Physical Slot: 2
Flags: bus master, fast devsel, latency 0, IRQ 112, NUMA node 0
Memory at f2000000 (64-bit, prefetchable) [size=32M]
[virtual] Expansion ROM at eca00000 [disabled] [size=1M]
ethtool output:
ethtool -k ens2f0
Features for ens2f0:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
udp-fragmentation-offload: off
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: off [fixed]
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: off [fixed]
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off
rx-all: off
tx-vlan-stag-hw-insert: on
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: on [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off
esp-hw-offload: off [fixed]
esp-tx-csum-hw-offload: off [fixed]
rx-udp_tunnel-port-offload: on
linux kernel:
4.15.0-109-generic
Thanks in advance,
Tigran Martirosyan
