RTC battery power consumption in Jetson AGX Orin Industrial
Hi @Trumany
What is the expected nominal consumption on the RTC Battery supplying VCC_RTC pin ?
Thank you.
You can find the answer (up to 50uA) in Orin module datasheet in DLC.
Hi Trumany
Is this the document? I can’t see the description about RTC Battery in this file, can you point it out?
Also double check that I am asking about the AGX Orin Industrial Module.
Jetson_AGX_Orin_Series_Data_Sheet_DS-10662-001_v1.5.pdf (788.6 KB)
Sorry, I found the current consumption data of PMIC_BBATT.
Does this data also apply to AGX Orin Industrial Module?
Yes for Orin Industrial module.
