We are having an issue with Jetson Nano processors and need a technical support on this. The issue is as below:
In our custom board, when RTC battery is connected, the processor randomly not boots. Bootloader is not even initiated in this case. When RTC is disconnected, everything works fine all the time. Our connection order is “2032 RTC battery – SS34FA diode – Jetson BBAT pin”. Below are the list of additional findings during our investigation:
• We found out that the issue is not directly related to RTC battery connection. It always boots fine if RTC battery voltage is applied for the first time. It seems that issue occurs after Jetson starts to keep time data.
• After it runs for the first time, if battery voltage keeps connected, we can observe the issue in consecutive power-ups. (Not %100 but around %70-80 of the time)
• The issue is not happening with older production Jetson Nano processors. We have ones with 2019 production date and they work fine. The issue occurs with the one with 2022 date and with 2023 date.
• The issue is not happening with Xavier NX processors.
• Changing battery, diode, providing stable RTC voltage from power supply (everything related to RTC side) did not make an impact on the issue.
• We tried different JetPacks 4.6.1 and 4.6.4 to see if that made an impact but it didn’t.
• We checked the power-up timings when this occurs, but everything seems normal. Reset signal also goes high for a brief period but then goes low again.
• We are stuck in the current situation. We suspect if this may be related to PMIC MAX77620 in Jetson, which handles this RTC and power up sequence things, but we don’t have any information on that side and how time data can prevent SoM from booting.
Any help would be much appreciated.
