Hi @ShaneCCC
Confirmed your workaround can’t work.
Because the workaround is only create an symbolic /dev/rtc to /dev/rtc0.
That only can make timedatectl show a correct RTC time from rtc0.
But the system time sync mechanism is done by kernel driver.
You can check the dmesg to see it.
Provide a correct workaround: Set the option CONFIG_RTC_HCTOSYS_DEVICE as rtc0 in tegra_defconfig
After changed the option, the local, universal, and rtc time are all correct.
