RTC Module
I have some questions on the RTC Module:
  1. What is the time drift of the RTC Module?
  2. How often do I need to sync the RTC Module using Network time?
  3. Does the AGX need to be synced regularly with the RTC Module, or only at startup?
  4. Does the RTC Module have an internal battery? How often does it needs replacement? How do we know if the battery needs replacement?
Dear chee0007,
Regarding RTC Module topic, could you please refer to below link?
https://docs.nvidia.com/drive/active/5.1.0.2L/nvvib_docs/index.html#page/DRIVE_OS_Linux_SDK_Development_Guide%2FBoard%2Fboard_e3550.html
The module needs ACC Power external power not need internal battery.
Regarding RTC module setting, could you please refer to Obtaining and Setting the System Time part in the following links.
https://docs.nvidia.com/drive/drive_os_5.1.9.0L/nvvib_docs/index.html#page/DRIVE_OS_Linux_SDK_Development_Guide%2FSystem%2520Setup%2Fsystem_realtime_clock.html
https://devtalk.nvidia.com/default/topic/1058535/general/the-clock-setting-is-not-stable-on-agx/post/5376735/#5376735
