It’s an interesting question, I checked the code of nvstreammux
I used deepstream-test3
as an example and got the results I expected
This is the patch
diff --git a/sources/apps/sample_apps/deepstream-test3/deepstream_test3_app.c b/sources/apps/sample_apps/deepstream-test3/deepstream_test3_app.c
index 4c2cf00..e9d46e4 100644
--- a/sources/apps/sample_apps/deepstream-test3/deepstream_test3_app.c
+++ b/sources/apps/sample_apps/deepstream-test3/deepstream_test3_app.c
@@ -17,6 +17,7 @@
#include <string.h>
#include <sys/time.h>
#include <cuda_runtime_api.h>
+#include <inttypes.h>
#include "gstnvdsmeta.h"
#include "nvds_yml_parser.h"
@@ -101,6 +102,13 @@ tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
num_rects++;
+ // GstClockTime
+ struct timeval tv;
+ gettimeofday(&tv, NULL);
+ uint64_t clock = tv.tv_sec * 1000 + tv.tv_usec / 1000;
+ uint64_t delta = clock - frame_meta->ntp_timestamp / 1000000;
+ printf("clock = %" PRIu64 " ntp = %" PRIu64 " delta: %" PRIu64 "ms\n", clock, frame_meta->ntp_timestamp, delta);
g_print ("Frame Number = %d Number of objects = %d "
"Vehicle Count = %d Person Count = %d\n",
frame_meta->frame_num, num_rects, vehicle_count, person_count);
@@ -255,6 +263,7 @@ create_source_bin (guint index, gchar * uri)
g_object_set (G_OBJECT (uri_decode_bin), "cudadec-memtype", 0, NULL);
} else {
uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
+ configure_source_for_ntp_sync(uri_decode_bin);
if (!bin || !uri_decode_bin) {
@@ -445,7 +454,8 @@ main (int argc, char *argv[])
#ifdef __aarch64__
sink = gst_element_factory_make ("nv3dsink", "nvvideo-renderer");
#else
- sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
+ //sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
+ sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
#endif
@@ -532,6 +542,10 @@ main (int argc, char *argv[])
+ g_object_set (G_OBJECT (streammux), "live-source", 1, NULL);
+ g_object_set (G_OBJECT (streammux), "frame-duration", 0, NULL);
+ g_object_set (G_OBJECT (streammux), "attach-sys-ts", 0, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
If you want to use the ntp time
in rtcp
, you need to set both attach-sys-ts
and frame-duration
to 0
deepstream-app
is similar.
This is my result. You can see that the delay has not increased.
TP: 2024-06-11T12:16:34.079Z(1718108194079700138). NTP diff:33364781. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.192Z
clock = 1718108194193 ntp = 1718108194079700138 delta: 114ms
0:00:15.579209610 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.607745284(6607745284) NTP: 2024-06-11T12:16:34.113Z(1718108194113064935). NTP diff:33364797. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.223Z
clock = 1718108194224 ntp = 1718108194113064935 delta: 111ms
0:00:15.613469316 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.641107884(6641107884) NTP: 2024-06-11T12:16:34.146Z(1718108194146427535). NTP diff:33362600. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.257Z
clock = 1718108194258 ntp = 1718108194146427535 delta: 112ms
0:00:15.651864745 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.674470515(6674470515) NTP: 2024-06-11T12:16:34.179Z(1718108194179790166). NTP diff:33362631. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.296Z
clock = 1718108194297 ntp = 1718108194179790166 delta: 118ms
0:00:15.680095551 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.707833179(6707833179) NTP: 2024-06-11T12:16:34.213Z(1718108194213152830). NTP diff:33362664. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.324Z
clock = 1718108194325 ntp = 1718108194213152830 delta: 112ms
0:00:15.713640264 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.741195875(6741195875) NTP: 2024-06-11T12:16:34.246Z(1718108194246515526). NTP diff:33362696. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.357Z
clock = 1718108194358 ntp = 1718108194246515526 delta: 112ms
0:00:15.755680945 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.774558602(6774558602) NTP: 2024-06-11T12:16:34.279Z(1718108194279878253). NTP diff:33362727. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.399Z
clock = 1718108194400 ntp = 1718108194279878253 delta: 121ms
0:00:15.799888705 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.807921362(6807921362) NTP: 2024-06-11T12:16:34.313Z(1718108194313241013). NTP diff:33362760. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.444Z
clock = 1718108194445 ntp = 1718108194313241013 delta: 132ms
0:00:15.819295893 32314 0x7f39f4001f40 LOG nvstreammux_ntp gstnvstreammux_ntp.cpp:259:gst_nvds_ntp_calculator_get_buffer_ntp:<stream-muxer> Frame NTP calculated. mode: RTCP SR. source 0: PTS:0:00:06.841284153(6841284153) NTP: 2024-06-11T12:16:34.346Z(1718108194346603804). NTP diff:33362791. ntp_time_epoch_ns = 2024-06-11T12:16:32.977Z(1718108192977646331) ntp_frame_timestamp = 0:00:05.472326680(5472326680) System Time: 2024-06-11T12:16:34.463Z
clock = 1718108194464 ntp = 1718108194346603804 delta: 118ms
