RTS5411S CAM_I2C connection usage
Hello everyone,
I just wanted to confirm if the RTS5411S connection to the CAM_I2C is referenced or used somewhere on the source or dts files on the Jetson Nano.
Best Regards,
Juan Pablo.
Looks like it’s a usb hub, shouldn’t need any define in dts
HI @ShaneCCC,
It is a hub, however I can see in the schematic for the Jetson Nano Devkit rev a02 that this same USB hub has it’s I2C / SMBUS connected to the I2C camera bus.
In addition, the datasheet for this USB hub mentions that the SMBUS connection is enabled by default.
From those pieces of information, I assume this connection has a purpose and it should be located somewhere on a dts / source code / firmware binary.
Best Regards,
Juan Pablo.
I don’t see any dts define about the RTS5411S.
You can download the kernel and dts source code to check.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fkernel_custom.html%23
Hi @ShaneCCC,
I’ve already done so, I just wanted confirmation from Nvidia in case I might have missed something.
Best Regards,
Juan Pablo.
