RTSP Client Request Format
Hopefully this is the right place to post this.
I set up a gstreamer RTSP server.
I need to stream the camera video to my mobile app and need to write the RTSP client myself as there isn’t much support in the development environment I’m using.
Is there anywhere where I can get example requests for querying the jetson RTSP server? I’ve tried some online resources already but I wasn’t successful with my attempts.
BTW, I am successful in viewing the stream with VLC media player. However I would like my app to display the video now.
I don’t think the RFC is a good resource because it just provides guidelines.
I’m using gstreamer rtsp server as well.
Thank you.
[https://www.ietf.org/rfc/rfc2326.txt]
I am using the following rfc.
This would need other users to share experience. Generally we set up RTSP server through test-launch. In RTP client, we use VLC player or run gstreamer command with rtspsrc plugin. The steps are put in Jetson Nano FAQ
Not sure but this post may help:
c++ - Receiving RTSP stream using FFMPEG library - Stack Overflow
You may also have a look to rtspsrc plugin sources for details.
