Hello
I want to connect RTSP camera and record video
I use GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
but when I try to connect it with OpenCV it is not compatible
do you have an example code of RTSP connection and video recording?
Thank you for the help
The link you mentioned is not related to opencv, AFAIK.
[Well, you’ve edited link in the meantime, so it gets less clear!]
For using a rtsp source on Jetson to opencv, you may find many posts in this forum.
Thank you for your note
I fix the link that I use Nvidia inference for object detection
but it is not compatible with OpenCV for RTSP connection and recording
I want example of RTSP connection and recording video using this package
Sorry, but someone else would reply to what you want.
You may consider to use DeepStream SDK.
https://forums.developer.nvidia.com/t/announcing-developer-preview-for-deepstream-5-0/121619
We have existing implementation in deepstream-app. Please check and give it a try.
