hi,
i wrote a systemctl script to run my custom deepstream app,
app can be run successfully and kafka works that it can send informations to cloud, but no osd and rtsp output,
but if i run app as normal, osd can show and rtsp output, too, but systemctl will show nothing.
what’s that problem?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
hi,
yes, if without systemctl, i can get kafka, RTSP, and OSD working together.
but can not get RTSP and OSD if with systemctl.
i don’t need the root anthority by run the command normally, and making all files by sudo.
my command normally is this:
