RTSP in RTSP out, but result will be a screen blur
• Hardware Platform (Jetson)
• DeepStream Version 6.2
• JetPack Version (5.1.1)
• Issue Type( questions )
Hello, I have a Python program issue related to RTSP in RTSP out (which is adapted from the official routine without modifying the pipeline elements). When analyzing RTSP video streams, I am prone to blurry screens (the original video stream itself does not have blurry screens). I would like to ask how to solve this problem?
The following is a blurry screenshot of the video stream
The following is the pipeline code:
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ", i, " \n ")
        uri_name = args[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    print("Creating Pgie \n ")
    if gie=="nvinfer":
        pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    else:
        pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    print("Creating tiler \n ")
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvvidconv_postosd = Gst.ElementFactory.make(
        "nvvideoconvert", "convertor_postosd")
    if not nvvidconv_postosd:
        sys.stderr.write(" Unable to create nvvidconv_postosd \n")
    # Create a caps filter
    caps = Gst.ElementFactory.make("capsfilter", "filter")
    caps.set_property(
        "caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
    # Make the encoder
    if codec == "H264":
        encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
        print("Creating H264 Encoder")
    elif codec == "H265":
        encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
        print("Creating H265 Encoder")
    if not encoder:
        sys.stderr.write(" Unable to create encoder")
    encoder.set_property("bitrate", bitrate)
    if is_aarch64():
        encoder.set_property("preset-level", 1)
        encoder.set_property("insert-sps-pps", 1)
        #encoder.set_property("bufapi-version", 1)
    # Make the payload-encode video into RTP packets
    if codec == "H264":
        rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
        print("Creating H264 rtppay")
        rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
        print("Creating H265 rtppay")
    if not rtppay:
        sys.stderr.write(" Unable to create rtppay")
    # Make the UDP sink
    updsink_port_num = 5400
    sink = Gst.ElementFactory.make("udpsink", "udpsink")
    if not sink:
        sys.stderr.write(" Unable to create udpsink")
    sink.set_property("host", "224.224.255.255")
    sink.set_property("port", updsink_port_num)
    sink.set_property("async", False)
    sink.set_property("sync", 1)
    streammux.set_property("width", 1920)
    streammux.set_property("height", 1080)
    streammux.set_property("batch-size", 1)
    streammux.set_property("batched-push-timeout", 4000000)
    if gie=="nvinfer":
        pgie.set_property("config-file-path", "dstest1_pgie_config.txt")
    else:
        pgie.set_property("config-file-path", "dstest1_pgie_inferserver_config.txt")
    #Set properties of tracker
    config = configparser.ConfigParser()
    config.read('dstest2_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config.getint('tracker', key)
            tracker.set_property('enable_batch_process', tracker_enable_batch_process)
        if key == 'enable-past-frame' :
            tracker_enable_past_frame = config.getint('tracker', key)
            tracker.set_property('enable_past_frame', tracker_enable_past_frame)
        # if key == 'display-tracking-id' :
        #     tracker_display_tracking_id = config.getint('display-tracking-id', key)
        tracker.set_property('display-tracking-id', 0)
        # if key == 'tracking-id-reset-mode' :
        #     tracker_id_reset_mode = config.getint('tracking-id-reset-mode', key)
        tracker.set_property('tracking-id-reset-mode', 3)
    pgie_batch_size = pgie.get_property("batch-size")
    if pgie_batch_size != number_sources:
        print(
            "WARNING: Overriding infer-config batch-size",
            pgie_batch_size,
            " with number of sources ",
            number_sources,
            " \n",
        pgie.set_property("batch-size", number_sources)
    print("Adding elements to Pipeline \n")
    tiler_rows = int(math.sqrt(number_sources))
    tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
    tiler.set_property("rows", tiler_rows)
    tiler.set_property("columns", tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    sink.set_property("qos", 0)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(nvvidconv_postosd)
    pipeline.add(caps)
    pipeline.add(encoder)
    pipeline.add(rtppay)
    pipeline.add(sink)
    streammux.link(pgie)
    pgie.link(tracker)
    tracker.link(nvvidconv)
    nvvidconv.link(tiler)
    tiler.link(nvosd)
    nvosd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(caps)
    caps.link(encoder)
    encoder.link(rtppay)
    rtppay.link(sink)
Continuing the discussion from RTSP in RTSP out, but result will be a screen blur:
  1. does the following cmd has the blurry issue?
gst-launch-1.0 -v  uridecodebin uri=rtsp://xx  !  nv3dsink
  1. if using nv3dsink in code, is there still blurry issue?
  2. you can simplify the code to narrow down this issue. for example, you can link nvstreammux to nv3dsink to check.
Hi, fanzh, thank you for your help!
As for the first suggestion, I have tried and found that the video playback is very smooth without any screen blur.
The second suggestion is that the video stream is very laggy, and I encountered the same problem as this topic https://forums.developer.nvidia.com/t/error-a-lot-of-buffers-are-being-dropped-when-running-ds-sdk-python-sample-ipcamera-on-nano/110886/3, but I also found that there will be no screen blur.
The third suggestion is that after reducing the pipeline, it was found that the possible influencing factor is UDP sink, which is an unstable connection method. Is there any way to improve the problem?
you can lower the encoder bitrate to reduce the receiving issue at the player side.
