RTSP in RTSP out example on Jetson Orin nano
I am getting this error on Jetson Orin Nano. Is there an example to not use hardware encoding here?
Error: gst-resource-error-quark: Could not open device ‘/dev/nvhost-msenc’ for reading and writing. (7): /dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/v4l2_calls.c(651): gst_v4l2_open (): /GstPipeline:pipeline0/nvv4l2h264enc:encoder:
system error: Cannot allocate memory
• Hardware Platform (Jetson / GPU): Jetson
• DeepStream Version: 6.2
• JetPack Version (valid for Jetson only): 5.1.1-b56
• TensorRT Version: 8.5.2.2
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing): Trying to run the deepstream-rtsp-in-rtsp-out python sample
As there is no hardware encoder in the Orin Nano, the encoding plugin need to be changed to software encoder x264enc , please refer to the pipeline here: Software Encode in Orin Nano — Jetson Linux Developer Guide documentation (nvidia.com).
Hi, I’ve stuck with the same issue trying to run rtsp-in-rtsp-out example on a freshly set up Orin Nano. Have corrected the encoder from to nvv4l2h264enc to x264enc
And getting following error:
Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so’: /lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Please file a new topic with your logs to debug the issue, thank you.
