RTSP output of pipeline with multiple streammuxes
**• Hardware Platform (Jetson / GPU) Jetson
**• DeepStream Version 6.0
**• JetPack Version (valid for Jetson only) 4.6
**• TensorRT Version 8.0
**• Issue Type( questions, new requirements, bugs) Question
Hi folks,
I have a pipeline structure like this;
Different kind of sources are processed in separate branches of the pipeline. But there is an issue, when I watch the output streams, I saw that the streams from udpsink-oc and udpsink-hmnd elements are kinda weird.
Stream from udpsink-oc is like, as if there were 4 input source streams (half black screen). And for the udpsink-hmnd stream, its like there were 6 (2/3 black screen).
If I had to describe, something like that;
udpsink-oc;
udpsink-hmnd;
Do you have an idea what could be the possible reason for that?
Please:
input source-bin-00 to “sink_0” pad of nvstreammux-0,
input source-bin-02 to “sink_1” of nvstreammux-0,
input source-bin-01 to “sink_0” pad of nvstreammux-1,
input source-bin-03 to “sink_1” pad of nvstreammux-1,
input source-bin-04 to “sink_0” pad of nvstreammux-2,
input source-bin-05 to “sink_1” pad of nvstreammux-2
The index number of nvstreammux src pad will decide the source id, and the source id will impact nvmultistreamtiler. Please design the pipeline carefully.
Thanks Fiona,
I was about the write these too, managed to solve it earlier today.
