Rtsp-reconnect-interval + runtime_source_add_delete
• Hardware Platform (Jetson / GPU): dPU A40.
• DeepStream Version: 6.4-triton-multiarch.
• TensorRT Version: 8.6.1.6.
• NVIDIA GPU Driver Version (valid for GPU only): 535.146.02.
• Issue Type( questions, new requirements, bugs): questions.
I want to enable rtsp-reconnect-interval for number of times via deepstream_test3 python code example, then if failing to re-connect it will be deleted from the pipeline as implemented in runtime_source_add_delete python code example.
How i can do this via python code, thanks ?
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks.
please refer to this topic. nvurisrcbin also supports RTSP reconnection functionality after set rtsp-reconnect-interval property.
