RTSP server doesn't work when launched as subprocess or multiprocessing thread
I am trying write a Python script on my Jetson Orin that will start an RTSP server and stream the feed from a MIPI camera when a command is received from an Android phone. I can run the following pipeline with test-launch and I can open the stream in my Android app:
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=692, height=520 ! videorate ! video/x-raw(memory:NVMM), framerate=30/1 ! nvv4l264enc ! rtph264pay name=pay0 pt=96 config-interval=1
I created my own RTSP server in Python with the following code, if I launch this script as a standalone process I can open the stream in Android:
import sys
import gi
gi.require_version('GstRtspServer', '1.0')
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst, GstRtspServer
def startBroadcast(launchString, locationString):
    Gst.init(None)
    mainloop = GLib.MainLoop()
    server = GstRtspServer.RTSPServer()
    mounts = server.get_mount_points()
    factory = GstRtspServer.RTSPMediaFactory()
    factory.set_launch(launchString)
    mounts.add_factory(f"/{locationString}", factory)
    server.attach(None)
    print(f"stream ready at rtsp://127.0.0.1:8554/{locationString}")
    mainloop.run()
if __name__ == "__main__":
    for i, arg in enumerate(sys.argv):
        if i == 1:
            serverLaunchstring = arg
    launchString = 'nvarguscamerasrc sensor-id=0 ' \
        '! video/x-raw(memory:NVMM),width=692,height=520 ' \
        '! videorate ! video/x-raw(memory:NVMM),framerate=30/1 ' \
        '! nvv4l2h264enc ' \
        '! rtph264pay name=pay0 pt=96 config-interval=1'
    locationString = "test"
That’s all great, but if I run test-launch as a subprocess or if I run the above script using multiprocess.Process, I get the following errors and I cannot open the stream in Android or locally on the Jetson:
(python3:14143): GStreamer-WARNING **: 08:48:25.071: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(python3:14143): GStreamer-WARNING **: 08:48:25.077: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
I have seen these errors before and was able to resolve them using “export LD_PRELOAD=”, but it’s not working in this case.
Here is the Python script I am running:
mport time
import zmq
import subprocess
from base64 import b64encode
import rtspserver
from datetime import datetime
import multiprocessing
class Test_Server:
    streamThread = None
    selectedCamera = ""
    def doStuff(self):
        subprocess.check_output("ip neigh > test.txt", shell=True)
        ipLine = subprocess.check_output('''grep -risn "192.168.244" ./test.txt''', shell=True)
        x = str(ipLine).split()
        ipAddr = x[0]
        ipAddr = ipAddr[4:]
        context = zmq.Context()
        socket = context.socket(zmq.REP)
        socket.connect("tcp://" + ipAddr + ":2519")
        while True:
            message = socket.recv_string()
            print("Received: " + message)
            time.sleep(1)
            if message == "Play":
                response = "starting camera"
                #subprocess.call(["/home/camgian/Documents/WA/gst-rtsp-server-1.14.1/examples/test-launch", launchString])
                self.startStreamThread(launchString, locationString)     # USED THIS FOR NON-MIPI CAMS
            elif message == "Stop":
                response = "stoping camera"
                if self.streamThread:
                    self.streamThread.terminate()     # USED THIS FOR NON-MIPI CAMS
                    self.streamThread = None          # USED THIS FOR NON-MIPI CAMS
            else:
                response = "bad message"
            socket.send_string(response)
    def startStreamThread(self, launchString, locationString):
        self.streamThread = multiprocessing.Process(
            target=rtspserver.startBroadcast, args=(launchString, locationString), daemon=True)
        self.streamThread.start()
    testServer = Test_Server()
    testServer.doStuff()
Is this some threading issue or something else I don’t understand?
Any help would be appreciated.
It seems like the path may not be valid:
Please check if you include the lib in the environment.
Also you may try to build libgstnvvidconv.so and libgstnvvideo4linux2.so manually and try to link to the self built ones. See if it works.
I’m not sure this is the problem. The only time I have a problem is when I launch the RTSP server as a child process. If I launch the RTSP server as a stand-alone process, it runs with no problems using the exact same pipeline.
Is it fine to run RTSP server in stand-alone process? The issue seems specific to running child process.
I don’t want to launch the RTSP server until I am ready for it.
Basically, am building an Android app that will allow the user to select one of multiple cameras which might be connected to the Jetson. Theses cameras include USB webcams, ethernet cameras, and MIPI cameras. So the pipeline I need to use with the server will be drastically different depending on which camera.
Anyway, I figured out the problem or at least a solution.
If I start my main process from the command line as usual but change by ZMQ comms pipeline to spin up using multiprocess.Process, then start the RTSP server when ready also with multiprocess.Process, I no longer get any errors and everything works as expected.
