• Hardware Platform (Jetson Nano)
• DeepStream Version*deepstream-l4t 5.0.1-20.09-samples
• JetPack Version (4.5)
• TensorRT Version*7.1.3.0
• Issue Type( questions)
Hi guys,
I have a problem wth rtsp streams create by the deepstream-app. I can access the rtsp stream on my Windows10 Notebook with the VLC Player and SMPlayer. The Problem is that the stream is buffering every 3 to 4 seconds.
Changing the bitrate didn’t solve the problem. Only the video quality is much worse.
Maybe someone has an idea how to get rid of the buffering.
I use the following pipeline:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://…/…/streams/testfahrt1.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
cudadec-memtype=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=4000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=1
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=400000
profile=0
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=1
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=-1
width=640
height=360
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
model-engine-file=…/…/models/mobilenetv2_4classes/model.engine
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=255;100;20;1
bbox-border-color2=255;0;0;1
bbox-border-color3=0;128;0;1
bbox-border-color4=255;255;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_ssd.txt
[tests]
file-loop=0
