RTSP Stream from Virtual Camera
Hello All,
I have created a warehouse scene where I have installed a virtual camera. My only goal initially is to output an RTSP stream which can be viewed directly on VLC or any other streaming platform. For that I just need to generate a legitimate RTSP Link. I followed the following steps using replicator agent:
render_products = []
render_products.append(rep.create.render_product('/World/Camera', resolution=(1024,1024)))
writer = rep.WriterRegistry.get("RTSPWriter")
writer.initialize(device=0, annotator="rgb", output_dir="rtsp://<my_rtsp_server_IP>:8554/RTSPWriter")
writer.attach(render_products)
print("published")
When I run this script using the IP of my RTSP server, the script runs successfully without any errors. However, when I check for the published topic pertaining to RTSPWriter on my RTSP server (MediaMTX), I cannot find any trace of it. I am also not able to view the stream anywhere (e.g. VLC). I have the following questions:
  • Do I also need to pass the output from Isaac Sim to FFMPEG?
  • Is there a possible problem with the firewall or authentication settings in the RTSP server?
  • Is there any other way to output a virtual camera stream from Isaac Sim? Is there any other protocol except RTSP?
Please follow these instructions before using the RTSPWriter. Let us know if you still have issues afterwards.
