• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Jetson Orin AGX 64 Gbyte
Deepstream 6.4
Jetpack 6.0 DP
How can we synchronize metadata (object bounding boxes, classes etc) with an outgoing rtsp stream - e.g. for annotation later down the pipeline?
Is there a way to add e.g. the frame index to an outgoing RTSP stream, so that each frame there can be uniquely associated with metadata (boxes, object classes etc) for it?
the same question has been raised here in 2021:
Has there been any development on this since then?
The stream starts at the same time I am sending messages (with a frame index), so if frames get transmitted, of course that index could be useful to synchronize them - so curious how one would go about an synchronize the messages and the rtsp stream?
This is your customized protocol, it is not included in the RTSP stream. Please implement your own customization in your own way. DeepStream will not conflict to your customization.
