I need to start RTSP streaming from jetson Xavier.
For RTSP server, I’ve created gst rtsp server as suggested here:
RTSP streaming
As RTSP server is running, now I want to start stream on the box with FFmpeg from the command line as in here:
ffmpeg -re -stream_loop -1 -i ./Camera2.mp4 -c copy -f rtsp rtsp://localhost:8554/test
But it fails with the following error:
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘./Camera2.mp4’:
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf58.17.101
Duration: 00:00:30.00, start: 0.000000, bitrate: 7075 kb/s
Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuvj420p(pc, bt709), 3840x2160, 7074 kb/s, SAR 1:1 DAR 16:9, 25 fps, 25 tbr, 25k tbn, 50 tbc (default)
Metadata:
handler_name : VideoHandler
[rtsp @ 0x55a2434f50] method ANNOUNCE failed: 405 Method Not Allowed
Could not write header for output file #0 (incorrect codec parameters ?): Server returned 4XX Client Error, but not one of 40{0,1,3,4}
Can you please help me solve this issue? I’ve already tried with some other launch lines, but no success yet.
Thank you
