Hello there,
I’ve been working with 2 ISP cameras for a rtsp video stream with this working example.
Using the test-multicast.c example… this is the pipe that works.
gst_rtsp_media_factory_set_launch (factory, "( "
"nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=2160 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 sink_1::height=2160 ! nvvidconv ! video/x-raw(memory:NVMM) ! nvv4l2h264enc bitrate=60000000 ! h264parse ! rtph264pay name=pay0 pt=96 alsasrc ! audioconvert ! avenc_aac ! aacparse ! rtpmp4apay name=pay1 nvarguscamerasrc sensor_id=1 ! video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1 ! nvvidconv flip-method=2 ! video/x-raw(memory:NVMM),width=1920, height=1080, format=RGBA ! queue ! comp. nvarguscamerasrc sensor_id=0 ! video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1 ! nvvidconv flip-method=2 ! video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=RGBA ! queue ! comp. " ")");
Now, i wanted to try different cameras, this time are USB. I made some changes but i got an error i’m not able to find anywhere.
Error: unsupported transport RTP/AVP;unicast;client_port=59496-59497
Here’s the new pipeline.
"nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=640 sink_0::height=720 sink_1::xpos=640 sink_1::ypos=0 sink_1::width=640 sink_1::height=720 ! nvvidconv ! video/x-raw(memory:NVMM) ! nvv4l2h264enc bitrate=60000000 ! h264parse ! rtph264pay name=pay0 pt=96 alsasrc ! audioconvert ! avenc_aac ! aacparse ! rtpmp4apay name=pay1 v4l2src device=/dev/video1 ! video/x-raw, format=(string)YUY2, width=640, height=360,pixel-aspect-ratio=(fraction)1/1, framerate=30/1 ! nvvidconv flip-method=2 ! video/x-raw(memory:NVMM),width=640, height=360, format=RGBA ! queue ! comp. v4l2src device=/dev/video0 ! video/x-raw,format=(string)YUY2,width=640, height=360, pixel-aspect-ratio=(fraction)1/1, framerate=30/1 ! nvvidconv flip-method=2 ! video/x-raw(memory:NVMM),width=640, height=360, framerate=30/1, format=RGBA ! queue ! comp. " ")");
And this is the output from gst-device-monitor-1.0
Device found:
class : Video/Source
caps : video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
properties:
udev-probed = true
device.bus_path = platform-70090000.xusb-usb-0:2.4:1.0
sysfs.path = /sys/devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/video4linux/video1
device.bus = usb
device.subsystem = video4linux
device.vendor.id = 1b3f
device.vendor.name = GENERAL
device.product.id = 2002
device.product.name = "GENERAL\ WEBCAM"
device.serial = GENERAL_GENERAL_WEBCAM
device.capabilities = :capture:
device.api = v4l2
device.path = /dev/video1
v4l2.device.driver = uvcvideo
v4l2.device.card = "GENERAL\ WEBCAM"
v4l2.device.bus_info = usb-70090000.xusb-2.4
v4l2.device.version = 264701 (0x000409fd)
v4l2.device.capabilities = 2216689665 (0x84200001)
v4l2.device.device_caps = 69206017 (0x04200001)
gst-launch-1.0 v4l2src device=/dev/video1 ! ...
Thanks in advance.
