RTSPS server output
• 3060
• 6.2
• New requirements
We would like to integrate TLS into our RTSP server (RTSPS) at the end of the pipeline.
We are using GStreamer Python API and this feature is not available.
Do you have any suggestions?
Thank you
There is already c/c++ sample in GStreamer community. gstreamer/subprojects/gst-rtsp-server/examples/test-video.c at main · GStreamer/gstreamer (github.com)
You need to rewrite the code with gst-python bindings. GstRtspServer.RTSPAuth - Classes - GstRtspServer 1.0 (lazka.github.io)
Thanks for your answer.
What would be the best approach?
Use a lower-level library than GstRtspServer or rewrite the code with gst-python bindings?
Are there any Deepstream samples that create an RTSP output using something other than GstRtspServer?
It depends on your knowledge base. Both work. Please choose the suitable one according to your own skills and knowledge. It is only realated to GStreamer.
Do you have any guidelines to recommand for those solutions?
What do you mean by “guideline”? There is already c/c++ sample in GStreamer community. gstreamer/subprojects/gst-rtsp-server/examples/test-video.c at main · GStreamer/gstreamer (github.com)
