• DeepStream Version
• TensorRT Version
• The pipeline being used
Just from the error info input buffer mapinfo failed, it’s a memory problem.
1.Observe whether there is a large and continuous increase in memory when you run the pipeline.
2.Try to change the pipeline to nvvidconv_2->fakesink and see if it will happen again.
3.Try to change the pipeline to uridecodebin->streammux and see if it will happen again.
thanks for a quick reply.
Tested for (1) Observe whether there is a large and continuous increase in memory when you run the pipeline, No. Memory remains near constant.
(2) changed the sink to fakesink.
in this case, instaed of that error, after a while pipeline is just waiting.
Did you try the 3rd way to change source to uridecodebin? We recommend using uridecodebin when you run the rtsp source.
Could you share the source link to us?
so I created a new RTSP stream on the same device using this
and started the pipeline on that stream.
the pipeline runs for a while and then keeps waiting / gets stuck.
The latest version is DS6.1.1. You can update to this vesion. Or you can just give us a rtsp source link, we can debug this problem.
