I have a laptop ASUS TUF506IV-AS76 with GPU NVIDIA GeForce RTX 2060 and an external monitor Acer Predator XB323QK which has several options how to connect it - HDMI, USB C, DP, even USB 3.0 it would seem.
Connecting it over HDMI with 3840x2160 @ 120hz i get a very weird red color output on the monitor, any red text or element over black/dark background looks pixelated and screwed up. No amount of calibration or option fiddling fixes it.
However, changing the refresh rate to 3840x2160 @ 60hz does fixes this.
The laptop has HDMI 2.0b port.
Now, i tried connecting it over USB C and there is no display issues at all and i can get it to 3840x2160 @ 144hz even.
But when i connect it over USB C, there is a huge increase in GPU utilization without anything except desktop environment running. At 3840x2160 @ 144hz i get like 60-70% GPU utilization, ~60W/90W. When i turn it down to 3840x2160 @ 60hz - it’s half that: 30-40% GPU utilization, ~30W/90W.
Meanwhile connecting it over HDMI does not cause any increase in idle power consumption/gpu utilization at all, regardless of the setting.
It does look like a driver bug, any help regarding the issue is much appreciated.
Sat Jan 7 11:46:34 2023
| NVIDIA-SMI 525.78.01 Driver Version: 525.78.01 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| N/A 72C P0 57W / 90W | 150MiB / 6144MiB | 70% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1400 G /usr/lib/xorg/Xorg 149MiB |
