Hi, I’m reporting a fan control regression on my RTX 2080 that started around driver 581.x and has gotten worse on the current 610.x branch. I found a related report for the RTX 2070 Super that describes the same class of issue, so this doesn’t seem isolated to my card. Tested with clean DDU wipes between each driver version to rule out leftover installation issues — the problem persists regardless. Details below.
GPU: EVGA GeForce RTX 2080 XC Ultra (08G-P4-2183-KR), Turing architecture (TU104)
OS: Windows 11
Symptom:
- On driver 556.12: fan control works correctly via Precision X1 / MSI Afterburner
- Starting from driver 581.42: both fans report 0% speed and 0 RPM,
no control possible from any third-party software - On driver 610.x (current): regression has worsened — only one fan is now
detected/reported at all, still no control possible - Tested with a clean DDU (Display Driver Uninstaller) wipe + fresh install
before each version tested — issue persists, so this is not a leftover
driver residue problem
Impact: fans do not ramp up automatically under load either, risking
overheating / thermal safety shutdown of the card
Related reports already filed:
- RTX 2070 SUPER FE, drivers 550–580 (forums.developer.nvidia.com)
- RTX 2080 Black Gaming, drivers >560.70 (archived EVGA forums)
screenshot of Precision X1 :
gpuZ sensors:
Attached is a dxdiag output, should it help.
DxDiag.txt (131.7 KB)
