I tried to run my rtx3060 in dual boot mode on ubuntu 20.04. Unfortunatly, the nvidia drivers are not detected by the system. I’ll just dump everything, that might be helpful, hope you can help me out. Working on a Thinkpad E15 Gen4, AMD, the gpu is connected via R43SG M.2-PCIe Adapter.
nvidia-detect
Detected NVIDIA GPUs:
04:00.0 VGA compatible controller [0300]: NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] [10de:2504] (rev a1)
Checking card: NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] (rev a1)
Your card is supported by the default drivers.
Your card is also supported by the Tesla 470 drivers series.
It is recommended to install the
nvidia-driver
package.
-modinfo nvidia
filename: /lib/modules/5.15.0-67-generic/updates/dkms/nvidia.ko
firmware: nvidia/470.161.03/gsp.bin
alias: char-major-195-*
version: 470.161.03
supported: external
license: NVIDIA
srcversion: 6651300FD4B9D974BB30104
alias: pci:v000010DEdsvsdbc03sc02i00
alias: pci:v000010DEdsvsdbc03sc00i00
depends: drm
retpoline: Y
vermagic: 5.15.0-67-generic SMP mod_unload modversions
sig_id: PKCS#7
signer: dominik-ThinkPad-E15-Gen-4 Secure Boot Module Signature key
sig_key: 6E:E3:A2:84:7F:AC:D6:51:D3:31:0A:71:F9:33:5D:4B:D4:AD:82:60
sig_hashalgo: sha512
signature: 29:AE:3E:E9:28:7C:65:30:44:1A:14:99:49:17:E3:58:95:A8:B1:27:
E9:9F:A2:65:EC:76:E8:37:DE:63:0D:7F:A2:91:52:04:23:A5:8D:18:
45:D9:76:75:60:2B:17:8F:71:99:62:15:A3:9E:48:98:85:6D:1D:48:
79:70:A0:15:D2:94:4A:97:34:BE:8A:3C:65:A2:68:82:1B:50:57:CF:
D7:AC:18:35:55:FE:BC:4F:5C:81:2F:AB:B1:B9:17:04:7F:D7:E0:96:
EA:47:5B:C4:96:1F:71:1F:75:6A:9F:B2:9E:0B:F8:2F:AF:16:8A:9F:
A2:75:22:F9:3C:14:E3:23:59:AA:B9:55:2B:0F:5B:11:51:7F:CB:83:
24:C5:63:B2:66:F5:52:38:C0:82:D2:BD:4C:4C:0B:BA:CD:21:52:A1:
09:86:94:05:BF:32:43:2C:92:BC:6F:F8:C0:11:09:C5:DB:84:F0:91:
06:01:86:9B:DC:D9:55:03:5B:B8:A5:24:1B:D6:B4:7F:54:29:57:FB:
B8:11:4C:93:66:7B:D4:5F:60:9C:67:4B:1C:54:09:EE:1C:E1:B8:49:
27:59:E8:4C:16:2B:E3:5F:CF:4A:C6:CE:8E:16:BD:77:37:B7:E8:42:
EC:5A:54:B6:20:68:93:07:F2:C4:2F:2B:1D:89:82:89
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid…] (charp)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_EnableS0ixPowerManagement:int
parm: NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableGpuFirmware:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_ExcludedGpus:charp
parm: rm_firmware_active:charp
-nvidia-smi
No devices were found
-lspci | grep NVIDIA
04:00.0 VGA compatible controller: NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] (rev a1)
04:00.1 Audio device: NVIDIA Corporation GA106 High Definition Audio Controller (rev a1)
-sudo lshw -c video
*-display
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:04:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=nvidia latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
resources: iomemory:40-3f iomemory:40-3f irq:74 memory:fc000000-fcffffff memory:460000000-46fffffff memory:470000000-471ffffff ioport:2000(size=128) memory:fd080000-fd0fffff
*-display
product: Advanced Micro Devices, Inc. [AMD/ATI]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:05:00.0
version: c1
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list
configuration: driver=amdgpu latency=0
resources: iomemory:40-3f iomemory:40-3f irq:43 memory:480000000-48fffffff memory:490000000-4901fffff ioport:1000(size=256) memory:fd400000-fd47ffff
-neofetch
OS: Ubuntu 20.04.5 LTS x86_64
. Host: 21EES00100 ThinkPad E15 Gen 4
Kernel: 5.15.0-67-generic
Uptime: 8 mins
Packages: 1904 (dpkg), 7 (snap)
Shell: bash 5.0.17
Resolution: 1920x1080, 1920x1080
DE: GNOME
WM: Mutter
WM Theme: Adwaita
Theme: Yaru [GTK2/3]
Icons: Yaru [GTK2/3]
Terminal: gnome-terminal
CPU: AMD Ryzen 7 5825U with Radeon Graphics (16) @ 2.000GHz
GPU: NVIDIA GeForce RTX 3060 Lite Hash Rate
GPU: AMD ATI 05:00.0 Barcelo
Memory: 2803MiB / 14812MiB
-dkms status
nvidia, 470.161.03, 5.15.0-67-generic, x86_64: installed
rtbth, 3.9.8, 5.15.0-67-generic, x86_64: installed
dpkg -l |grep nvidia
ii libnvidia-cfg1-470:amd64 470.161.03-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-470 470.161.03-0ubuntu1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-450:amd64 450.216.04-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-compute-470:amd64 470.161.03-0ubuntu1 amd64 NVIDIA libcompute package
rc libnvidia-compute-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-decode-470:amd64 470.161.03-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-470:amd64 470.161.03-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-470:amd64 470.161.03-0ubuntu1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-470:amd64 470.161.03-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-470:amd64 470.161.03-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-470:amd64 470.161.03-0ubuntu1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii nvidia-compute-utils-470 470.161.03-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-detect 525.89.02-1 amd64 NVIDIA GPU detection utility
ii nvidia-dkms-470 470.161.03-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-driver-470 470.161.03-0ubuntu1 amd64 NVIDIA driver metapackage
ii nvidia-driver-local-repo-ubuntu2004-470.82.01 1.0-1 amd64 nvidia-driver-local repository configuration files
ii nvidia-kernel-common-470 470.161.03-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-470 470.161.03-0ubuntu1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.16~0.20.04.2 all Tools to enable NVIDIA’s Prime
ii nvidia-settings 530.30.02-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-470 470.161.03-0ubuntu1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-470 470.161.03-0ubuntu1 amd64 NVIDIA binary Xorg driver
ls -l /usr/lib/x86_64-linux-gnu/libnvidia* /usr/lib/x86_64-linux-gnu/libcuda*
lrwxrwxrwx 1 root root 12 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libcuda.so → libcuda.so.1
lrwxrwxrwx 1 root root 21 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libcuda.so.1 → libcuda.so.470.161.03
-rw-r–r-- 1 root root 22037736 Okt 19 02:27 /usr/lib/x86_64-linux-gnu/libcuda.so.470.161.03
lrwxrwxrwx 1 root root 24 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so → libnvidia-allocator.so.1
lrwxrwxrwx 1 root root 33 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.1 → libnvidia-allocator.so.470.161.03
-rw-r–r-- 1 root root 98688 Okt 19 02:03 /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.470.161.03
-rw-r–r-- 1 root root 762400 Okt 19 02:05 /usr/lib/x86_64-linux-gnu/libnvidia-cbl.so.470.161.03
lrwxrwxrwx 1 root root 18 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so → libnvidia-cfg.so.1
lrwxrwxrwx 1 root root 27 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.1 → libnvidia-cfg.so.470.161.03
-rw-r–r-- 1 root root 221552 Okt 19 02:03 /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.470.161.03
-rw-r–r-- 1 root root 55972120 Okt 19 02:28 /usr/lib/x86_64-linux-gnu/libnvidia-compiler.so.470.161.03
-rw-r–r-- 1 root root 30280848 Okt 19 02:23 /usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.470.161.03
lrwxrwxrwx 1 root root 21 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so → libnvidia-encode.so.1
lrwxrwxrwx 1 root root 30 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1 → libnvidia-encode.so.470.161.03
-rw-r–r-- 1 root root 116768 Okt 19 02:03 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.470.161.03
lrwxrwxrwx 1 root root 18 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so → libnvidia-fbc.so.1
lrwxrwxrwx 1 root root 27 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so.1 → libnvidia-fbc.so.470.161.03
-rw-r–r-- 1 root root 129784 Okt 19 02:03 /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so.470.161.03
-rw-r–r-- 1 root root 32103664 Okt 19 02:25 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.470.161.03
-rw-r–r-- 1 root root 639848 Okt 19 02:04 /usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.470.161.03
-rw-r–r-- 1 root root 13036984 Okt 19 02:24 /usr/lib/x86_64-linux-gnu/libnvidia-glvkspirv.so.470.161.03
lrwxrwxrwx 1 root root 18 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-ifr.so → libnvidia-ifr.so.1
lrwxrwxrwx 1 root root 27 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-ifr.so.1 → libnvidia-ifr.so.470.161.03
-rw-r–r-- 1 root root 219736 Okt 19 02:03 /usr/lib/x86_64-linux-gnu/libnvidia-ifr.so.470.161.03
lrwxrwxrwx 1 root root 17 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-ml.so → libnvidia-ml.so.1
lrwxrwxrwx 1 root root 26 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.1 → libnvidia-ml.so.470.161.03
-rw-r–r-- 1 root root 1828056 Okt 19 02:04 /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.470.161.03
lrwxrwxrwx 1 root root 27 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-ngx.so.1 → libnvidia-ngx.so.470.161.03
-rw-r–r-- 1 root root 3306056 Okt 19 02:05 /usr/lib/x86_64-linux-gnu/libnvidia-ngx.so.470.161.03
lrwxrwxrwx 1 root root 19 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so → libnvidia-nvvm.so.4
lrwxrwxrwx 1 root root 23 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so.4 → libnvidia-nvvm.so.4.0.0
-rw-r–r-- 1 root root 26659608 Okt 19 02:28 /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so.4.0.0
lrwxrwxrwx 1 root root 30 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-opencl.so.1 → libnvidia-opencl.so.470.161.03
-rw-r–r-- 1 root root 17811080 Okt 19 02:28 /usr/lib/x86_64-linux-gnu/libnvidia-opencl.so.470.161.03
lrwxrwxrwx 1 root root 26 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so → libnvidia-opticalflow.so.1
lrwxrwxrwx 1 root root 35 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.1 → libnvidia-opticalflow.so.470.161.03
-rw-r–r-- 1 root root 47096 Okt 19 02:04 /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.470.161.03
lrwxrwxrwx 1 root root 29 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so → libnvidia-ptxjitcompiler.so.1
lrwxrwxrwx 1 root root 38 Okt 19 05:43 /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.1 → libnvidia-ptxjitcompiler.so.470.161.03
-rw-r–r-- 1 root root 11148472 Okt 19 02:13 /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.470.161.03
-rw-r–r-- 1 root root 82666936 Okt 19 02:30 /usr/lib/x86_64-linux-gnu/libnvidia-rtcore.so.470.161.03
-rw-r–r-- 1 root root 18456 Okt 19 02:03 /usr/lib/x86_64-linux-gnu/libnvidia-tls.so.470.161.03
lrwxrwxrwx 1 root root 38 Mär 5 01:48 /usr/lib/x86_64-linux-gnu/libnvidia-vulkan-producer.so → libnvidia-vulkan-producer.so.525.89.02
-sudo journalctl -b0 -g nvidia
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia: loading out-of-tree module taints kernel.
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia: module license ‘NVIDIA’ taints kernel.
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 510
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia 0000:04:00.0: enabling device (0002 → 0003)
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia 0000:04:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.108.03 Thu Oct 20 05:10:45 UTC 2022
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 510.108.03 Thu Oct 20 05:00:22 UTC 2022
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: [drm] [nvidia-drm] [GPU ID 0x00000400] Loading driver
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: [drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000400] Failed to allocate NvKmsKapiDevice
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: [drm:nv_drm_probe_devices [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000400] Failed to register device
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: nvidia-uvm: Loaded the UVM driver, major device number 507.
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.4/0000:04:00.1/sound/card0/input29
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.4/0000:04:00.1/sound/card0/input30
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.4/0000:04:00.1/sound/card0/input31
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.4/0000:04:00.1/sound/card0/input32
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:02.4/0000:04:00.1/sound/card0/input33
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:02.4/0000:04:00.1/sound/card0/input34
Mär 05 09:22:35 dominik-ThinkPad-E15-Gen-4 kernel: input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:02.4/0000:04:00.1/sound/card0/input35
Mär 05 09:22:36 dominik-ThinkPad-E15-Gen-4 audit[836]: AVC apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=836 comm=“apparmor_parser”
Mär 05 09:22:36 dominik-ThinkPad-E15-Gen-4 audit[836]: AVC apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=836 comm=“apparmor_parser”
Mär 05 09:22:36 dominik-ThinkPad-E15-Gen-4 kernel: audit: type=1400 audit(1678004556.948:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=836 comm=“apparmor_parser”
Mär 05 09:22:36 dominik-ThinkPad-E15-Gen-4 kernel: audit: type=1400 audit(1678004556.948:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=836 comm="apparmor_p>
Mär 05 09:22:37 dominik-ThinkPad-E15-Gen-4 systemd[1]: Starting NVIDIA Persistence Daemon…
Mär 05 09:22:37 dominik-ThinkPad-E15-Gen-4 systemd[1]: Starting nvidia-powerd service…
Mär 05 09:22:37 dominik-ThinkPad-E15-Gen-4 /usr/bin/nvidia-powerd[906]: nvidia-powerd version:1.0(build 1)
Mär 05 09:22:39 dominik-ThinkPad-E15-Gen-4 systemd[1]: Started NVIDIA Persistence Daemon.
Mär 05 09:22:42 dominik-ThinkPad-E15-Gen-4 systemd[1]: nvidia-powerd.service: Main process exited, code=exited, status=1/FAILURE
Mär 05 09:22:42 dominik-ThinkPad-E15-Gen-4 systemd[1]: nvidia-powerd.service: Failed with result ‘exit-code’.
Mär 05 09:22:42 dominik-ThinkPad-E15-Gen-4 systemd[1]: Failed to start nvidia-powerd service.
Mär 05 09:22:51 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1202]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event16)
Mär 05 09:22:51 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1202]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event17)
Mär 05 09:22:51 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1202]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event18)
Mär 05 09:22:51 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1202]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event19)
Mär 05 09:22:51 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1202]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event20)
Mär 05 09:22:51 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1202]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event21)
Mär 05 09:22:51 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1202]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event22)
Mär 05 09:22:52 dominik-ThinkPad-E15-Gen-4 optimus.desktop[1472]: Could not find provider with name NVIDIA-0
Mär 05 09:23:04 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1792]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event16)
Mär 05 09:23:04 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1792]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event17)
Mär 05 09:23:04 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1792]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event18)
Mär 05 09:23:04 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1792]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event19)
Mär 05 09:23:04 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1792]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event20)
Mär 05 09:23:04 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1792]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event21)
Mär 05 09:23:04 dominik-ThinkPad-E15-Gen-4 /usr/lib/gdm3/gdm-x-session[1792]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event22)
Mär 05 09:23:05 dominik-ThinkPad-E15-Gen-4 optimus.desktop[2033]: Could not find provider with name NVIDIA-0
Mär 05 09:23:14 dominik-ThinkPad-E15-Gen-4 snap-store[2278]: not handling error download-failed for action refresh: W: GPG error: file:/var/nvidia-driver-local-repo-ubuntu2004-470.82.01 Release: The following >
E: The repository ‘file:/var/nvidia-driver-local-repo-ubuntu2004-470.82.01 Release’ is not signed.
Sorry for the wall of text, hope that gives somewhat of an insight.
Thanks in advance!
nvidia-bug-report.log.gz (279.9 KB)
