Hi all,
we’re currently trying to get a laptop’s dedicated NVIDIA RTX 3060 (mobile) card running.
Installed are the proprietary nvidia drivers in version 550 on Pop!_OS. It seems though that these - at least regarding vulkan - do not work correctly. This has been tried in the “NIVIDIA only” and “Hybrid” mode of Pop!_OS. All outputs below have been gathered in the Hybrid mode; it doesn’t seem to make any difference to the “NIVIDIA only” mode though.
Appended is the vulkaninfo
log file which also throws the following error messages when being run with __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia vulkaninfo > vulkaninfo.log
ERROR: [Loader Message] Code 0 : loader_scanned_icd_add: Could not get 'vkCreateInstance' via 'vk_icdGetInstanceProcAddr' for ICD libGLX_nvidia.so.0
WARNING: [Loader Message] Code 0 : terminator_CreateInstance: Failed to CreateInstance in ICD 3. Skipping ICD.
The vulkaninfo.log
doesn’t contain any references to the RTX 3060 which seems weird.
Also, running e.g. the CARLA simulator with sudo docker run --privileged --gpus all --net=host -e DISPLAY=$DISPLAY carlasim/carla:0.9.12 /bin/bash ./CarlaUE4.sh
of course with the NVIDIA Container toolkit being installed throws an “Incompatible Vulkan driver found! Cannot find a compatible Vulkan driver (ICD)” exception.
Running __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo
results in the following output:
name of display: :0
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 50
Current serial number in output stream: 51
Running nvidia-smi
results in this (also when being run in Pop!_OS’ “NVIDIA only” mode):
No devices were found
Running lshw -c video
though shows the correct information regarding the graphics card:
*-display
description: 3D controller
product: GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom fb
configuration: depth=32 driver=nvidia latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
resources: iomemory:fa0-f9f iomemory:fc0-fbf irq:71 memory:d0000000-d0ffffff memory:fa00000000-fbffffffff memory:fc00000000-fc01ffffff ioport:3000(size=128) memory:d1000000-d107ffff
*-display
description: VGA compatible controller
product: Cezanne
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:05:00.0
version: c6
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list fb
configuration: depth=32 driver=amdgpu latency=0 resolution=1920,1080
resources: iomemory:fc0-fbf iomemory:fc0-fbf irq:44 memory:fc10000000-fc1fffffff memory:fc20000000-fc201fffff ioport:1000(size=256) memory:d1400000-d147ffff
Thanks in advance for any help! If you need any more information do not hesitate to ask :).
nvidia-bug-report.log.gz (302.3 KB)
vulkaninfo.log (121.3 KB)
