I’m trying to run an application using CUDA 9 on a machine with a 3060, however it fails. I can run the same application with an identical environment on a 2060. As explained in the release notes, CUDA 9 should be compatible. Is there something obvious I’m missing?
Some more info…
I have a RTX 3080 laptop GPU with driver version 471.41 and CUDA 11.4. The application I’m running uses a Anaconda virtual environment with CUDA 9, and works as expected on the RTX 2060 (don’t have exact version readily available).
