Dears;
I have a problem. I can not reach the Geforce RTX3070 in any way. I tried to pick the RTX 3070 by optimus-manager command but not working. Getting error while running nvidia-smi and nvidia-settings command on terminal.
Here are my logs;
nvidia-bug-report.log.gz (109.3 KB)
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: Micro-Star product: GE76 Raider 10UG v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-17K2 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E17K2IMS.10C date: 02/19/2021
Battery: ID-1: BAT1 charge: 89.8 Wh (94.5%) condition: 95.0/95.0 Wh (100.0%) volts: 17.0
min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A status: Unknown
Memory: RAM: total: 15.44 GiB used: 2.31 GiB (15.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
CPU: Info: 8-Core model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
rev: 2 cache: L2: 16 MiB bogomips: 70421
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 4459 3: 3760
4: 2995 5: 1963 6: 1224 7: 943 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Micro-Star MSI
driver: N/A bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
bus-ID: 04:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Intel driver: igc v: kernel port: N/A bus-ID: 05:00.0 chip-ID: 8086:3101
class-ID: 0200
IF: enp5s0 state: down mac: <filter>
WAN IP: <filter>
Bluetooth: Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 953.87 GiB used: 9.36 GiB (1.0%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2210 MTFDHBA1T0QFD size: 953.87 GiB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P6MA001 temp: 44.9 C
scheme: GPT
Message: No optical or floppy data found.
Partition: ID-1: / size: 306.53 GiB used: 9.36 GiB (3.1%) fs: ext4 dev: /dev/nvme0n1p5
label: N/A uuid: 0b269f6e-ae42-4678-a141-98f23f298567
ID-2: /boot/efi size: 511 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
label: N/A uuid: 44BE-B193
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/nvme0n1p2 size: 16 MiB fs: ext4 label: N/A
uuid: cfa584ff-15e8-4ea6-85e1-4d4ac03d9fa2
ID-2: /dev/nvme0n1p3 size: 328.35 GiB fs: ntfs label: N/A uuid: A02AD7952AD766B6
ID-3: /dev/nvme0n1p4 size: 312.5 GiB fs: ntfs label: N/A uuid: 9406D39F06D38122
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-9:3 info: SteelSeries ApS SteelSeries KLC type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 300mA
chip-ID: 1038:1122 class-ID: 0300
Device-3: 1-10:4 info: SteelSeries ApS SteelSeries ALC type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 1038:1134 class-ID: 0300
Device-4: 1-14:5 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 20 Gb/s
Sensors: System Temperatures: cpu: 60.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 358 Uptime: 20m wakeups: 1 Init: systemd v: 249 Compilers: gcc: 11.1.0
Packages: pacman: 1122 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.08
dmesg
[ 66.041737] audit: type=1131 audit(1636140428.946:131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 66.179567] audit: type=1334 audit(1636140429.089:132): prog-id=23 op=UNLOAD
[ 71.788876] nvidia: loading out-of-tree module taints kernel.
[ 71.788883] nvidia: module license 'NVIDIA' taints kernel.
[ 71.788883] Disabling lock debugging due to kernel taint
[ 71.795283] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 71.803510] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ 71.803939] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 71.804020] NVRM: request_mem_region failed for 0M @ 0x0. This can
NVRM: occur when a driver such as rivatv is loaded and claims
NVRM: ownership of the device's registers.
[ 71.804024] nvidia: probe of 0000:01:00.0 failed with error -1
[ 71.804037] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 71.804038] NVRM: None of the NVIDIA devices were initialized.
[ 71.804140] nvidia-nvlink: Unregistered the Nvlink Core, major device number 510
[ 76.404711] audit: type=1101 audit(1636140439.309:133): pid=2531 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="mgg" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 76.404789] audit: type=1110 audit(1636140439.309:134): pid=2531 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 76.406240] audit: type=1105 audit(1636140439.312:135): pid=2531 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 76.415867] audit: type=1106 audit(1636140439.322:136): pid=2531 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 76.415889] audit: type=1104 audit(1636140439.322:137): pid=2531 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 90.959669] audit: type=1101 audit(1636140453.866:138): pid=2534 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="mgg" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 90.959776] audit: type=1110 audit(1636140453.866:139): pid=2534 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
search -i nvidia
egl-wayland 1:1.1.7-1 extra
EGLStream-based Wayland external platform
mhwd-nvidia-390xx 390.144-1 core
MHWD module-ids for nvidia 390.144
mhwd-nvidia 470.63.01-1 core
MHWD module-ids for nvidia 470.63.01
linux513-nvidia 470.63.01-14 extra
NVIDIA drivers for linux.
lib32-nvidia-utils 470.63.01-1 multilib
NVIDIA drivers utilities (32-bit)
nvidia-utils 470.63.01-2 extra
nvidia-prime 1.0-4 extra
NVIDIA Prime Render Offload configuration and utilities
mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.07.28 false PCI
video-modesetting 2020.01.13 true PCI
Warning: No installed USB configs!
mhwd -l
> 0000:01:00.0 (0300:10de:249d) Display controller nVidia Corporation:
video-nvidia 2020.11.30 false PCI
video-linux 2018.05.04 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:9bc4) Display controller Intel Corporation:
